Bosch 1617 Grommet Size - Router Forums
 3Likes
  • 1 Post By vchiarelli
  • 1 Post By Stick486
  • 1 Post By hal
post #1 of 10 (permalink) Old 01-17-2018, 12:13 PM Thread Starter
vchiarelli's Avatar
First Name: Vince
Default Bosch 1617 Grommet Size
Hello all: I've searched the forum bur cannot find anything specific to my question. I've got a Bosch 1617 and am looking to put a grommet into the shaft, but don't know what size. I know that some of you have done this. Can you tell me specifically what size grommet you've used and save me a few trips to the hardware store.
Vince
vchiarelli is offline
post #2 of 10 (permalink) Old 01-17-2018, 12:25 PM
I use a half inch diameter grommet, which is just about 1/8th inch thick. It's a tight fit, but the thin edges allow it to slip in place. I used a 3/8 ths dowel to press it in place. That worked in my 1617. When I put the bit in, I basically just drop it in and press down lightly. When you lock the bit in, it will position itself just right and the next bit will do the same. Particularly nice if you're using a door or trim set with matched-height shanks.
post #3 of 10 (permalink) Old 01-17-2018, 01:00 PM
measure the OD of the collet and add a fuzz...
the fuzz keeps it from falling out...
3/6'' wall thickness and you'll be golden...
post #4 of 10 (permalink) Old 01-17-2018, 01:17 PM Thread Starter
vchiarelli's Avatar
First Name: Vince
Thanks Tom and stick. I had one in there but it disappeared and I don't remember the size. Will that 1/2 inch work with the concave portion at the bottom
DesertRatTom likes this.
post #5 of 10 (permalink) Old 01-17-2018, 02:55 PM
old coasty's Avatar
First Name: Bob
Where can you get a 1/2" grommet? I have a lot of old ones from my electronic days (no 1/2"), and the only ones I find now are all 3'8 " and 5/8".
old coasty is offline
post #6 of 10 (permalink) Old 01-17-2018, 03:35 PM
Semipro's Avatar
First Name: John_*
most hardware storescarry them, big box stores you get them online.
Semipro is offline
post #7 of 10 (permalink) Old 01-17-2018, 04:01 PM
the 3/16'' comps for that...
vchiarelli likes this.
post #8 of 10 (permalink) Old 01-17-2018, 08:38 PM
I couldn't find the grommets nearby and ordered a bunch from Amazon. I have enough to last me another 150 years. There was no issue with the concave bottom in my 1617s.
post #9 of 10 (permalink) Old 01-18-2018, 09:14 AM
hal
First Name: hal
For years I have used faucet washers, just find one that is 1/8 thick and will fit in the shaft. works great.
BrianS likes this.
hal is offline
post #10 of 10 (permalink) Old 01-18-2018, 10:34 AM Thread Starter
vchiarelli's Avatar
First Name: Vince
I've picked up 9/16"OD grommets and beveled faucet washers, 1/2" x 1/4"(thick). One of those should work and yup, got extras.
Bosch 1617 collet will not tighten bit Gorm New Member Introductions 29 01-09-2017 02:49 PM
Bosch 1617 electric cord WSC General Routing 13 03-18-2014 08:16 PM
Bosch 1617 ESV fine adjustment question horn man General Routing 5 01-21-2010 05:07 PM
Bosch 1617 em14 General Routing 4 08-02-2008 11:03 AM
1617 Bosch and 1/2 & 1/4 collets dtaylor15 General Routing 1 03-10-2006 05:07 PM
