Bosch router fine adjustment problem - Router Forums
 12Likes
post #1 of 11 (permalink) Old 01-17-2018, 01:17 PM Thread Starter
Send a message via AIM to tdbecher Send a message via MSN to tdbecher Send a message via Yahoo to tdbecher
Default Bosch router fine adjustment problem
I have a Bosch 1613EVS. The fine adjustment knob is very "sticky". I've tried oiling the threaded shaft under the adjustment knob, but it still requires great force to turn the knob, in either direction. Can't figure out how to get inside the mechanism to diagnose further. The exploded view available on line is little help. Any ideas how to fix or dig deeper? Thx
tdbecher is offline
post #2 of 11 (permalink) Old 01-17-2018, 02:51 PM
Hey, TDB; welcome!
Oil was probably a contributing factor. What ever compacted dust was in there has likely turned to gundge.
You need to flush it through/out. My first choice, before the oil was added, would have been Mineral spirits (paint thinner) but now I'd switch to Isopropyl alcohol (Rubbing Alcohol) and a lot of it!
Taking it apart is really the most certain way of doing it properly...call Bosch Customer Service. They're very helpful.
https://www.manualslib.com/manual/47...?page=8#manual
jj777746 likes this.
DaninVan is offline
post #3 of 11 (permalink) Old 01-17-2018, 03:29 PM
and use dry lube when you reassemble...
post #4 of 11 (permalink) Old 01-17-2018, 03:49 PM Thread Starter
Thanks. I think I will contact Bosch to find out how to get in there. The oil I've put in hasn't leaked out anywhere so I'm concerned any "flushing" agent will also have a tough time getting out - and probably take a long time in the process. So, my plan would be to open it up, clean, dry, and then use dry lube. Let's see what Bosch says....
DaninVan and Roy Drake like this.
tdbecher is offline
post #5 of 11 (permalink) Old 01-17-2018, 08:58 PM Thread Starter
Smile in conclusion....
So, I talked with Bosch "customer service". They were worthless. But, I did manage to then get myself transferred to "technical service" where the guy knew what he was talking about. Anyway, for any others who may need to get into the guts of their router...
First, take the motor housing off the top of the router and release the coil springs holding the brushes and retract the brushes. This is needed to allow the motor body to slide out of the housing and to reinsert it later. Next remove 4 screws from the base of the router body. You need a very short screwdriver or ratchet with phillips bit to get to these. Lock the plunge base lever. Next remove the adjustment knob and pry off the lock washer that is holding a couple of washers and a spring washer. I used a flat blade and pried it off. Now the motor housing can be lifted off the plunge base, but only after the plunge lock lever has been released. Caution, when you release the lock lever there is a long compressed spring inside the handle on that side of the router that will push the housing away from the base. The spring is about 10" long and will want to get away from you. At this point you can remove the adjustment knob shaft and mechanism from the housing and clean it.
The issue, for me, was that the screw mechanism was clogged with some fine wood dust mixed with oil. The mechanism is a combination of a cast aluminum male threaded piece that screws into a nylon female piece and it is not made to shed any stuff that might get in there. For mine, there was only a few threads that had material on them. I wiped them clean with a wire brush and the mechanism then worked fine. I don't think dry lube would help the situation because when dirt gets in there, these threads are gonna seize up, lube or not.
tdbecher is offline
post #6 of 11 (permalink) Old 01-17-2018, 09:46 PM
So basically, your generic "gundge" then...
Great that you got the info you need, TDB; giving Bosch credit they did talk you through it.
You realize that now you're the resident 1613 authority ...
DaninVan is offline
post #7 of 11 (permalink) Old 01-17-2018, 10:23 PM
hawkeye10's Avatar
First Name: Don
Hello and welcome. Glad you got it fixed. Please put your first name where it says "NA". We try to be friendly here. Stick around and maybe you can have some fun talking woodworking.
Roy Drake likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 11 (permalink) Old 01-19-2018, 11:25 AM Thread Starter
Thanks Roy, will do. I'm Tom, btw. I'm off now to fix some other tools that have "sticky" issues. I've probably used oil inappropriately in several areas where I should have just bit the bullet, disassembled, then cleaned. Regards
TenGees likes this.
tdbecher is offline
post #9 of 11 (permalink) Old 01-19-2018, 11:58 AM
Nickp's Avatar
First Name: Nick
Originally Posted by DaninVan View Post
Hey, TDB; welcome!
...turned to gundge.
You need to flush it... ]
Out of curiosity I looked for a proper definition of "gundge"... only because "gundge" and "flush" were used closely together in your response. This of course led me to verify whether I was getting the right image or not...
Nick
Nickp is offline
post #10 of 11 (permalink) Old 01-19-2018, 01:13 PM
keep in mind he's north of north...
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Quick Review Bosch MRC23EVSK Modular Router System jgt1942 General Routing 3 12-15-2012 08:40 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
Bosch 1617EVSPK Router table adjustment dtaylor15 Table-mounted Routing 10 07-27-2007 10:19 AM
