Instant panel saw. Sorta. - Router Forums
 11Likes
  • 3 Post By JOAT
  • 2 Post By DesertRatTom
  • 2 Post By Marco
  • 2 Post By RainMan 2.0
  • 1 Post By TenGees
  • 1 Post By CharleyL
post #1 of 9 (permalink) Old 01-22-2018, 06:56 PM Thread Starter
JOAT's Avatar
First Name: Theo
Default Instant panel saw. Sorta.
Found this the usual way, looking for something else entirely unrelated. Problem was, it was on Pinterest. Twice. At two different sites, and could find nothing more than the photo, no other information available. But that should be ample. Very simple, add a circular saw guide, and you've got a workable panel saw.
Did I mention that I hate Pinterest?
Marco, Danman1957 and ggom like this.
JOAT is online now
post #2 of 9 (permalink) Old 01-22-2018, 07:02 PM
First Name: Ken
That would be a lot easier than reaching across a four-foot panel.
kklowell is offline
post #3 of 9 (permalink) Old 01-22-2018, 07:08 PM
Really needs to have a guide of some sort, maybe clamp a guide to the workpiece. Maybe two rails to fit round the sides of the saw to trap it to cut a nice, straight line?
RainMan 2.0 and ggom like this.
post #4 of 9 (permalink) Old 01-22-2018, 07:26 PM
Marco's Avatar
I don't care for Pinterest either.
Shop guy and RainMan 2.0 like this.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #5 of 9 (permalink) Old 01-22-2018, 07:32 PM
First Name: Ken
Two rails in conjunction with some stick on measuring tapes almost make it a real panel saw. Like this tape maybe https://www.google.com/shopping/prod...AaAnlrEALw_wcB
kklowell is offline
post #6 of 9 (permalink) Old 01-22-2018, 09:46 PM
First Name: Ken
Found this idea during my evening Youtube cruising.
kklowell is offline
post #7 of 9 (permalink) Old 01-22-2018, 11:43 PM
RainMan 2.0's Avatar
Kind of a neat concept, but I can’t see it being stable enough when your pushing the skill saw , and as Tom said it needs a guide of some sort . A Track saw is the answer for me .
And I’m with you guys as I hate Pinterest also
DesertRatTom and ggom like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #8 of 9 (permalink) Old 01-23-2018, 10:14 AM
TenGees's Avatar
First Name: Paul
I agree that it could use a guide but even a rough cut (following a pencil line) would be easier in that set-up. Looks like it could be a little tippy cutting near the top and if the floor isn't level it could bind there.
RainMan 2.0 likes this.
TenGees is offline
post #9 of 9 (permalink) Old 01-23-2018, 10:30 AM
CharleyL's Avatar
First Name: Charley
I think I'll stick with my cutting table, straight edge clamps and circular saw with base that rides on the straight edge clamps that I have. Although not truly a track saw, I can break up sheets at waist level on the cutting table and nothing falls to the ground. I can get accurate cuts, but usually size the pieces about 1/4" over size and trim them down to exact size on my Unisaw. I do this outside my shop in the driveway, since the shop is too small to handle full size sheets inside. I've posted information and pictures of my system before. I still find no need to buy a "track saw" or even build a "panel saw". Now that I'm getting older (75) lifting and carrying full sheets is becoming my latest challenge, and I have recently bought and built a few items to help with this.
Charley
TenGees likes this.
Central North Carolina
CharleyL is offline
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 08:39 PM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
Keeping Panel from sticking to Rail/Stile Joint groff5 Tools and Woodworking 5 03-01-2010 03:40 PM
rasied panel doors jce Table-mounted Routing 6 12-13-2004 12:45 PM
