Kreg rip-cut saw guide - alternative - Page 2 - Router Forums
 7Likes
post #11 of 14 (permalink) Old 02-03-2018, 09:44 AM
Originally Posted by roofner View Post
I have one and you can do precision cuts with it but had trouble cutting anything over 10 inches wide. Also there is a problem when the
saw crosses the end of the rip it tends to become unsteady. Your better off with something like the ez track system or a plywood ripping guide.
https://tombuildsstuff.blogspot.com/...cular-saw.html
The home-made guide that I used for years was just like that - 1/4" tempered hardboard, but with a 3/4" plywood fence as the saw base has a rolled edge. The hardboard was screwed to the fence, and I know that I moved it a couple of times as the "edge" got worn, and once because I went to a different saw. I was running out of room for the clamps on the section outboard of the fence when I finally retired it. Now I see that the dovetail clamps that go with the MatchFit Dado Stop are good for this application as they are below the guide - do a search, there are several YouTube videos showing different ways the clamps can be used other than this.
I use the EZ Edge Guide for ripping, working well now that I've corrected a cou0ple of problems, still working on a couple of ideas to improve it. It has a long enough fence that there's good contact with the plywood edge both at the start and finish of the cut.
tomp913 is offline
post #12 of 14 (permalink) Old 02-03-2018, 11:17 AM Thread Starter
JOAT's Avatar
First Name: Theo
Guess I made a good call then, deciding to make rather than get one. I know a saw guide would be more accurate, but for what I want it for, a homemade one will work just fine.
Of course I'm not busy, I did it right the first time.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is offline
post #13 of 14 (permalink) Old 02-03-2018, 01:17 PM
roofner's Avatar
First Name: Gary
I only used mine once to rip the last board for my deck that meet the house wall 16 foot deck board.
roofner is offline
post #14 of 14 (permalink) Old 02-04-2018, 06:11 PM
I have an EZSmart Universal Edge Guide (UEG) acronym. I have a Makita 6 1/2" cordless saw mounted and it performs very well. It is more money but when I wanted on to see if it could do what I wanted it worked like I thought.
https://www.eurekazone.com/product_p/ezuegsb1.htm
Marty
Minnesota Marty is offline
Hi jazzzbo New Member Introductions 8 10-01-2017 09:41 PM
Andrew from Cedarville, OH StrawHOC New Member Introductions 11 09-25-2017 10:54 AM
Kreg Tool Rip-Cut Saw Guide Frankj3 Lobby 18 10-19-2016 05:05 PM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Calculating Start/Finish Cut Location YellowLabProject Starting Off 10 10-31-2006 09:57 AM
