router or shaper? - Router Forums
post #1 of 4 (permalink) Old 07-01-2005, 04:23 PM Thread Starter
larryproctor_2000's Avatar
First Name: larry
Send a message via MSN to larryproctor_2000 Send a message via Yahoo to larryproctor_2000 Send a message via Skype™ to larryproctor_2000
Default router or shaper?
looking for input at the time for buying a good router and table or a shaper , any thoughts seem about the same price thx
larryproctor_2000 is offline
post #2 of 4 (permalink) Old 07-01-2005, 05:59 PM
If this is an either / or situation, then I'd recommend getting the router and table. Since you can use the router independant of the router table, this combination is much more versatile than a shaper. This depends on the type of work you plan on doing as well.
jeff12002 is offline
post #3 of 4 (permalink) Old 07-01-2005, 06:03 PM
-Sam-'s Avatar
First Name: Sam
Thumbs up
Ditto on jeff12002's reply!
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline
post #4 of 4 (permalink) Old 07-01-2005, 06:31 PM
Larry, although they perform many of the same functions there is a world of difference. It's a safe bet you wouldn't want to throw a shaper into your vehicle to run and do a repair for a friend. By the same token you wouldn't want to run router bit's non-stop all day long for heavy commercial production. For the average person a router and table are the cost effective solution. Production shops benefit from the shapers longer lasting cutters and greater power. Most shapers cost substantially more than a good router and table set up.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
router table or shaper? flyboy8224 Starting Off 6 12-03-2007 02:39 AM
