dados and rabbits - Router Forums
post #1 of 4 (permalink) Old 03-05-2009, 03:14 PM Thread Starter
Default dados and rabbits
I have a dewalt 625 in a router table. in fact its the same table norm built on the new yankee work shop. I have read and read about dados. So I will ask for your educated opinoins here. Which is the best method for making dados? on a table saw or using a router table. THe product will be white faced melamine and I need to make 1/2 wide by 1/4 deep dados and rabbits for cabinet construction. Thanks
coupe is offline
post #2 of 4 (permalink) Old 03-05-2009, 03:17 PM
dovetail_65's Avatar
First Name: Dovetail
There are more ways to Dado then you can learn in a lifetime I bet!
To me there are many great ways and it depends on the specific project you are going to use the dado for.
A table saw or router can both be used to get great dadoes, but even then there are many ways of using the table saw and router to make the dadoes.
I have a jig I use for the router, I will try to get some pics up while others chime in.
dovetail_65 is offline
post #3 of 4 (permalink) Old 03-05-2009, 03:27 PM
Hi coupe
A good set of dado blades, is Not cheap, the low ones will still empty your pocket,,,a good router bit will do the same job at about 1/10 the price..
and sometimes a bit lower, Norm A. has all the bucks he needs to buy the high end tools..
But it's up to you
post #4 of 4 (permalink) Old 03-05-2009, 06:11 PM
Gene Howe's Avatar
First Name: Gene
My dados are done with a hand held router and a very simple jig. First, because it's such a PITA to change my saw over to the dado blade function. Second, because with my jig, I can get dead on accurately sized dados. And, third because I'm getting too old to lug the work to the saw table. Especially when I'm doing a bunch!
With rabbets, it depends on how many and how big. If it's a lot, I'll go through the hassle of switching over to the dado blade. Just a few....I use the router.
Gene Howe
Snowflake, AZ
Gene Howe is online now
