Weight of Dado Blade Or Vibration Is Causing Blade To Lower During The Cut - Page 2 - Router Forums
 18Likes
post #11 of 30 (permalink) Old 03-10-2018, 09:10 PM
After looking at the manual, I see where the tilt lock just locks the forward trunion on the tilt mechanism. The shaft for the elevation doesn't lock.
Must have done too good a job lubricating. Maybe there is a way you can make something to prevent the elevating wheel from rotating once it is set for the correct cut height. Some kind of clamp with a thumb knob you loosen to raise the blade then tighten to hold that wheel from turning.
Herb Stoops is online now
post #12 of 30 (permalink) Old 03-10-2018, 09:17 PM
First Name: Richard
That is a terrible design flaw. Surely there is someway to fabricate a locking mechanism.
Herb Stoops likes this.
Shop guy is offline
post #13 of 30 (permalink) Old 03-10-2018, 10:17 PM
It will take a little thinking ,because you have to allow the blade elevation shaft and wheel to move when the blade is rotated on an angle to cut a bevel.
Maybe an arm with a hole in one end cut for a clamping collar, and a slot in the handle to slide on a stud with a thumb nut to loosen and tighten down to hold in position.
post #14 of 30 (permalink) Old 03-11-2018, 07:13 AM
First Name: Larry
Jim if your getting vibration you might want to check your blades to see if you have any carbide teeth missing. I have the same
dato blades and I noticed yesterday that I have 3 carbide teeth missing on one blade.
Knot working is online now
post #15 of 30 (permalink) Old 03-11-2018, 08:51 AM
DonkeyHody's Avatar
First Name: Andy
This is obviously a dangerously unsafe situation. (Yes, I know I redundantly said it twice.) Perfect excuse to buy a new saw.
DaninVan and difalkner like this.
DonkeyHody is offline
post #16 of 30 (permalink) Old 03-11-2018, 09:34 AM
old Steve's Avatar
First Name: Steven
My small Delta saw has always done the same thing with a dado blade...I usually have to put a clamp on the blade raising/lowering knob to hold the height position.
old Steve is offline
post #17 of 30 (permalink) Old 03-11-2018, 09:48 AM Thread Starter
Contributor of the Month
yup...
the grease isn't helping either...
On a positive note the grease does make it real easy to raise and lower the blade.
JIMMIEM is offline
post #18 of 30 (permalink) Old 03-11-2018, 09:51 AM Thread Starter
I bought this saw when Jimmy Carter was in the White House. Unfortunately a new table saw isn't in the budget right now.
JIMMIEM is offline
post #19 of 30 (permalink) Old 03-11-2018, 09:55 AM Thread Starter
All the teeth are present. This dado set isn't recommended for and underpowered saw, which mine is. But, unfortunately I own it and it has worked well when it stayed put.
I'll see if I can rig up something to lock the blade height.
JIMMIEM is offline
post #20 of 30 (permalink) Old 03-11-2018, 09:57 AM Thread Starter
Thank You......I'll see what I can figure out.
JIMMIEM is offline
I Have Been Encouraged To Write Jerry Bowen Lobby 5 11-24-2014 09:32 AM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Dumb table saw question Bill from Indy Tools and Woodworking 19 08-17-2012 03:39 PM
What do you use to sand the edge of plywood? volunteers Tools and Woodworking 8 04-29-2012 10:28 PM
Question about saw blades. N'awlins77 Tools and Woodworking 21 03-21-2011 07:47 PM
