Weight of Dado Blade Or Vibration Is Causing Blade To Lower During The Cut - Page 3 - Router Forums
 18Likes
post #21 of 30 (permalink) Old 03-11-2018, 10:59 AM
Originally Posted by JIMMIEM View Post
On a positive note the grease does make it real easy to raise and lower the blade.
where have you been the last several years...
and dry lube will work even better.. (I like TriFlow)
grease and WD collect cud by the bucket full especially under the saw...
post #22 of 30 (permalink) Old 03-11-2018, 11:00 AM
It probably has an old drive belt, which might contribute to vibration. You might try changing it out for a a flexible link belt. You buy a length and then assemble it to exact length. I also think the lubrication is a big factor. My Laguna TS doesn't have a height lock and it is rock steady. The Laguna TS takes a slight effort to crank up but has a large, heavy wheel that reduces the effort needed to turn it. I think I'd also clean out the grease, particularly if the slipping increased or began after adding the grease fittings. Grease and TS mechanical parts don't mix well.
post #23 of 30 (permalink) Old 03-11-2018, 11:04 AM
often those belts treat the symptom and not the cause...
best to look into the cause of the vibration 1st...
if it's and old belt that is causing vibration a new belt will fix that and be way cheaper too...
post #24 of 30 (permalink) Old 03-11-2018, 11:08 AM
Don't know if it makes a difference, but the Dado listed under "Recommended Accessories" in the manual above is only 7" diameter - that might make a difference.
Herb Stoops likes this.
tomp913 is offline
post #25 of 30 (permalink) Old 03-11-2018, 11:38 AM
so would a 6'' be better still...
post #26 of 30 (permalink) Old 03-11-2018, 12:26 PM Thread Starter
Contributor of the Month
The grease is inside the trunion housing. The owner of InLine Industries sent me a video on how to install grease fittings. I installed the grease fittings about 10 years ago. A couple of years ago I had to replace the arbor bearing which required removing the trunion. The grease inside the trunion was free of saw dust.
I have a link belt.
I saw some recommendations to raise the blade to final position rather than lowering the blade into final position. I'll also check all fasteners on the underside of the saw. Somebody also recommended hanging a vise grip on the blade elevation crank to give it some weight to prevent it from moving from vibration.
JIMMIEM is offline
post #27 of 30 (permalink) Old 03-11-2018, 12:28 PM Thread Starter
The manufacturer's literature did not recommend the 8" dado set for an underpowered saw. Mine is only 1 hp.
JIMMIEM is offline
post #28 of 30 (permalink) Old 03-11-2018, 12:51 PM
I have a link belt.
my bad...
carry on...
post #29 of 30 (permalink) Old 03-11-2018, 01:03 PM
Drill a hole somewhere near the hand wheel roughly level with it. Put a bolt i the hole that has at least 1/2" of unthreaded shoulder on it. Double nut the threaded portion so that the unthreaded portion stands out from the saw. Attach a bungee strap from the hand wheel to the bolt once adjusted. The tension on the bungee strap should be enough to hold it in place. That's about as simple a fix as I can think of. Easy and quick to attach and easy and quick to unattach.
post #30 of 30 (permalink) Old 03-11-2018, 10:43 PM
Oh well, we tried.
I Have Been Encouraged To Write Jerry Bowen Lobby 5 11-24-2014 09:32 AM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Dumb table saw question Bill from Indy Tools and Woodworking 19 08-17-2012 03:39 PM
What do you use to sand the edge of plywood? volunteers Tools and Woodworking 8 04-29-2012 10:28 PM
Question about saw blades. N'awlins77 Tools and Woodworking 21 03-21-2011 07:47 PM
