Cabinet Doors - Router Forums
post #1 of 6 (permalink) Old 03-12-2009, 08:40 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Cabinet Doors
I always loved the active construction work and during my retirement years I do renovation jobs because I like it plus to keep me busy and get some extra cash for my hobbies. My last project was a new kitchen as per attached photos. This project started by first replacing the floor which was in a very bad shape and when the customer saw the big difference between the new ceramics floor and the existing old cabinets decided to change the cabinets too. Since their budget was small, I only used ¾” thick pine frame on the doors with a 1/8” groove to accept veneered plywood in the center. From start to finish it took me a total of 29 days work.
There is a possible new kitchen project and so far I think that they will go with some pretty expensive cabinets. In order to prepare myself I have these questions:
1. My router is 10 Amps. Is this big enough to do raised door panels?
2. Are the “matched set” stile and rail bits a good choice?
3. Do the vertical raised panel bits do a good job or it’s better to go with horizontal raised panel bits?
4. Is the horizontal raised panel bits with back cutters a good choice?
5. Are the Cathedral and Ached door templates a good investment or I should make my own?
Thank you
Nicolas
kolias is offline
post #2 of 6 (permalink) Old 03-12-2009, 09:00 PM
Ralph Barker's Avatar
First Name: Ralph
There's a good discussion on point in the Bits section, I believe. Some prefer vertical to horizontal for raised panels, but Charles (from Freud) says the horizontal bits make a smoother cut. Your router might handle the vertical bits, but might have trouble with the horizontal ones, depending on the wood being used. The horizontal bits are quite large, and should be run at around 10,000 rpm, I think.
Matched sets for rails and stiles are much better than mis-matched sets.
- Ralph
Ralph Barker is offline
post #3 of 6 (permalink) Old 03-12-2009, 09:01 PM
First Name: Johann
Nice job. I will be interested in seeing the answers to your questions. I'm thinking about doing the same on a couple of houses we own and have built a horizontal router table for that purpose.
Johann George is offline
post #4 of 6 (permalink) Old 03-12-2009, 10:14 PM
I use a horizontal table to make panels and have been happy with it. I have a big router that could handle the big bits. I have just been very satisfied with what I have.
vikingcraftsman is offline
post #5 of 6 (permalink) Old 03-12-2009, 10:43 PM
Hi Nicolas
1. Yes
2. Yes, it's a must
3. Do the vertical raised panel bits,Yes, But see below #4
4. Yes, if you are going to make Cathedral and Ached doors
5. Yes, buy a set
Thank you
Nicolas
post #6 of 6 (permalink) Old 03-13-2009, 09:22 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you all
I'm happy that my 10A router is ok. If and when I finish this job, then I will be asking suggestions to buy a new baby.
Nicolas
kolias is offline
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 03:26 PM
Water Damaged oak cabinet doors joeboxer JoeBoxer's Gallery 20 09-26-2011 10:28 PM
how to get all my kitchen cabinet doors all the same hight taylormaid General Routing 7 02-25-2009 11:52 PM
Need a table to do cabinet doors dynamowhum Table-mounted Routing 4 12-07-2008 10:07 PM
kitchen cabinet doors help puretrick Tools and Woodworking 15 06-05-2005 04:28 PM
