How do you figure this??? - Page 3 - Router Forums
 26Likes
post #21 of 22 (permalink) Old 04-04-2018, 05:32 PM
Any angle is just a product of the rise and run. The sine function is the height of the rise/ the length of the hypotenuse. It really isn't hard and a calculator will do the work for you. You can calculate the sine using the lengths and then use the inverse sine function to find the angle. (Divide height by length of the hypotenuse; click the "INV" button then the "sin to the -1" button).
This can be handy to know. When you are building a roof you should work in rise and run, typically a 4' rise for every 12' of run or a 4 in 12 pitch. But if you are angling the ends with a chop saw you need to know the angle. The hypotenuse (the length of the slope) is the square root of (4 squared + 12 squared) which = 12.65 . 4/12.65= .316 which is the sine value. The angle, the inverse sine, is approximately 18.4 degrees.
The unfortunate part of the way our schools teach math is that they don't show you how to apply it to everyday problems because if they had I think way more of us would have learned it and remembered it.
TenGees likes this.
post #22 of 22 (permalink) Old 04-04-2018, 07:36 PM
Terry Q's Avatar
Or you could learn how to use a framing square. Itís amazing the things people have made without the use of trigonometry or graph paper. A framing square was a carpenterís calculator and could be used for calculating many things.
TenGees likes this.
Terry Q is offline
I'm stuck trying to figure out how to glue this up Everend Tools and Woodworking 7 01-02-2017 01:22 PM
My First Yard Figure OutoftheWoodwork Show N' Tell 14 11-21-2012 04:50 PM
starting to figure things out ctsooner Table-mounted Routing 10 04-12-2010 08:17 AM
adjusting depth how to figure out the right depth CFLfan Portable Routing 3 02-06-2010 06:22 PM
I'll figure it out lbirdwell New Member Introductions 3 05-21-2007 10:27 PM
