plexiglass - Router Forums
post #1 of 11 (permalink) Old 03-19-2009, 11:52 AM Thread Starter
Default plexiglass
Hubby's not home and I want to cut a piece of plexiglass, was going to use jigsaw, but was advised not to. I was told to use roter or dremel. Any suggestions???
Conch29 is offline
post #2 of 11 (permalink) Old 03-19-2009, 12:35 PM
AxlMyk's Avatar
Possibly a table saw. Make the first cut VERY light, then continue a little at a time. Remove any flash before taking the next cuts.
AxlMyk is offline
post #3 of 11 (permalink) Old 03-19-2009, 12:50 PM
HI Conch29
I would suggest you use the jig saw,,,the table may not be the safe way for you if you have not used it b/4..
I would suggest putting some masking tape on both sides of the Plexiglas and pickup a fine tooth blade,one that's for metal should do the trick..
test cut some scrap b/4 you make the real cut...to get the feel of it..
post #4 of 11 (permalink) Old 03-19-2009, 01:14 PM
levon's Avatar
First Name: levon
hi Conch,
welcome to our forum.
levon
levon is offline
post #5 of 11 (permalink) Old 03-19-2009, 07:12 PM
kp91's Avatar
First Name: Doug
How big a piece and how thick is it? small thin stuff can be scribed and snapped kind of like glass if you only need straight cuts. Jigsaw works too, but if you don't have the feed rate right you either can gum up the blade if you go too slow or crack it if you feed too fast.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 11 (permalink) Old 03-19-2009, 07:43 PM
TWheels's Avatar
There are special router bits designed for cuiting plexiglass and other plastics. They are designated as O-flute. As far as I know they are available only as straight bits but come in a variety of diameters.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 11 (permalink) Old 03-20-2009, 10:52 AM
First Name: Joe
Hi Conch29
You might try the "sandwich" method. Put the plexi between two pieces of thin panelling, fastening them together with double sided tape and then cut away with a small circular saw (jig saw may tend to wander). You did not say how big or how thick this piece is, so helpful info can be varied. Good luck.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline
post #8 of 11 (permalink) Old 03-21-2009, 06:59 AM
First Name: Thrifty
Conch,
Is the plexiglass stiff or a bit flexible? If it's a bit flexiable (lexan) and similar in thickness to window glass, it can be cut on a table saw with a ripping blade (~24 tooth). Thicker pieces can also be cut, but you have to be careful with the heat build-up at the cut....shallow cuts and low blade tooth number.
If it's actually old style plexiglass, stiff and brittle, I would use a router with a straight bit and spinning at low speed.
TTG
Thrifty Tool Guy is offline
post #9 of 11 (permalink) Old 03-21-2009, 06:20 PM
First Name: Aart
Hi. I went to a glass company to purchase some plexiglass, and they just used a table saw to cut it. I've since done the same at home and it works. I've also used the router and the dremel tool. you have to watch it with the router and dremel tool, because sometimes it just melts instead of cuts, and actually melts back together. Don't forget to use eye and ear protection!!!
stairguy is offline
post #10 of 11 (permalink) Old 03-21-2009, 06:45 PM
xplorx4's Avatar
First Name: Jerry
Greetings (your name here) and welcome to the forum. At HD you can buy a scribing tool and cut it like glass by making several scribes. in the same place of course, and then break it on the edge of a table.
Only problem I can see if you use the table saw is if it is too big, too flexible and too unweilding to handle. The tape on both sides and the jigsaw would also work.
I guess if you could tell us how big it is and how thick it would help for us to make the best recommendation.
Lamentations 3:22-23
xplorx4 is offline
Cutting plexiglass Drick Tools and Woodworking 20 06-10-2009 10:36 AM
cutting plexiglass glassman Router Bits - Types and Usage 5 08-27-2008 01:56 AM
Bit Speed on Plexiglass???? garycurtis Table-mounted Routing 23 06-28-2008 01:18 PM
cutting plexiglass froglips7846 New Member Introductions 5 04-15-2008 09:54 AM
Cutting Plexiglass Julie Lobby 19 11-12-2007 09:49 AM
