An I Box question. - Router Forums
 8Likes
  • 1 Post By hawkeye10
  • 1 Post By Cherryville Chuck
  • 4 Post By CharleyL
  • 2 Post By CharleyL
post #1 of 8 (permalink) Old 04-08-2018, 10:52 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default An I Box question.
When making a box with an I Box do you let the fingers come out however they fall or center them on the width of the board? I am making the first box out of ply and it will be 5" X 5" X 12" long. It's a recipe box.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 8 (permalink) Old 04-08-2018, 11:04 AM
I'm not sure how you would center them but I've only used mine a few times. You can only start one way that I know if. I've made mine wider than I needed and trimmed them after. Especially if you want the lid to box line to be in a certain relation to the position of the fingers.
post #3 of 8 (permalink) Old 04-08-2018, 11:56 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Chuck, in this video it shows you how to center the fingers in a given width. I really wanted to see what others were doing. to find out how to center it go to about 38 minutes into the video and that will put you close.
artman60 likes this.
post #4 of 8 (permalink) Old 04-08-2018, 12:07 PM
I only had occasion to use mine a few times and it's been sitting waiting since so I didn't remember that option Don. I just used it the basic way when I did it.
hawkeye10 likes this.
post #5 of 8 (permalink) Old 04-09-2018, 12:44 PM
CharleyL's Avatar
First Name: Charley
Or, just plan on trimming the last partial joint off after cutting the box joints. The box then looks better but is slightly smaller. I do it this way, if the box size isn't critical. Trying to center them never seemed to gain much, since then you can have partial joints both top and bottom. I also frequently remove one complete joint when cutting the lid off, to keep the box joint pattern looking right. You can plan for this by adding the width of the joint to the height of your box, so you end up with the desired box height after you finish.
Charley
Central North Carolina
CharleyL is offline
post #6 of 8 (permalink) Old 04-09-2018, 02:42 PM
Charley
You said something similar in the post about the 10 mm box that you made, "Yea, it becomes one finger shorter that way though. I usually don't do it, unless I'm trying to make it "look better" and the box is tall enough to be able to loose one finger pair for this." I meant to ask a question about that at the time and forgot - if you take out a strip equal to one finger, don't you wind up with an unbalanced pattern? - ie Face, End, End, Face, etc., rather than Face, End, Face, End, etc. - although you do say "finger pair" later in the quote which seems to make sense, and also agrees with the picture. So, for a 3/8" box joint, you would have to make the box 3/4" taller to allow cutting an adjacent finger and space. Thanks.
tomp913 is offline
post #7 of 8 (permalink) Old 04-09-2018, 03:09 PM
Charley
My plan is to start the joints from one end and cut off the other, uneven end. So I'll calculate depth in multiples of 3/8ths (using the 1/4-3/8ths Freud blades), or half inch using a dado stack. That should make it fairly easy to get the final size I want. Doesn't seem to me that there's much advantage to starting in the middle? I'd rather have the bottom of the box be reliably flat so I'm making a parallel cut on what will be the top.
post #8 of 8 (permalink) Old 04-09-2018, 06:22 PM
CharleyL's Avatar
First Name: Charley
Tom,
The best way to avoid sequencing mistakes is to make both ends of each side the same way IE, Pin first. Then make the front and back with the space first. This is why I label the front and back "A" and the two ends "B" It doesn't matter what you label them as long as you keep them in pairs. Doing it this way also allows you to put the best side of each board facing out when it's time for you to glue them up, because both ends of each pair will be cut the same.
If you make each board pin first on one end and space first on the other end, I can almost guarantee that you will foul something up and the box won't go together.
After cutting both ends of the "A" sides and are about to begin cutting the "B" sides, Take one of the "A" sides and place the first space over the pins in the I-Box Jig with the rest of the board and pins to the right. Then place the end of the "B" board in the jig to the left of the "a" board, but tight up against it. Doing this will space the "B" board correctly and your first cut in it will begin at the right place. Once this first cut is made, remove the "A" board and complete cutting the end of the "B" board. Do this same procedure when you begin cutting each end of the "B" board. Also, always cut both ends of the boards the same. When the first end is complete, rotate the board end for end so the right edge of the board remains on the right (rotate away from you, not to the side) because the pin sequence needs to begin from the same board edge on both ends of each board. Pin first on the "A" board ends, and space first on the same edge of the "B" board ends.
Consider yourself a master if you get this all right on your first box jointed box and all 4 sides fit together the first time that you do this. Once you get this sequence right, it will be easy from then on.
Charley
DesertRatTom and hawkeye10 like this.
CharleyL is offline
Router Table Dust Collection Box Design D Brooks L Table-mounted Routing 10 03-16-2017 02:09 PM
Another combination plane blade box hack rwyoung Show N' Tell 8 01-10-2011 08:41 PM
Belated anniversary jewelry box Ghidrah Show N' Tell 14 07-04-2010 03:47 PM
DIY Box Joint jiq question tbreland Jigs and Fixtures 60 03-13-2010 04:56 AM
Intro and Box Joint Question rdennison New Member Introductions 6 09-21-2007 04:26 PM
