glue-up fit - Router Forums
post #1 of 12 (permalink) Old 03-22-2009, 05:10 PM Thread Starter
Default glue-up fit
Hey guys, Perhaps you can help! Just finished a new project Made a new hatch door for friend's sail boat(see hatch door show-n-tell) checked, checked and checked again. did a dry fit and everything fit fine except when I did the glue up. Spread the glue evenly but one side did not want to go together. still had a small gap. filler solved the problem, just wondering if anyone else has had this problem??? John
jbishop is offline
post #2 of 12 (permalink) Old 03-23-2009, 01:47 AM
xplorx4's Avatar
First Name: Jerry
I had that problem with a tray I made, ever thing fir perfect in the dry run, but with glue the fit was not so perfect. A friend, shop teacher type, told me the joints were a little too tight. Let's see what others have to say on the subject.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 12 (permalink) Old 03-23-2009, 04:02 PM
Hamlin's Avatar
First Name: Ken
Hi,
You do need to leave a little room for the glue.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 12 (permalink) Old 03-23-2009, 04:55 PM
AxlMyk's Avatar
It's possible air was trapped in the joint.
AxlMyk is offline
post #5 of 12 (permalink) Old 03-23-2009, 05:44 PM
Hi John
It looks like the plywood panel is keeping the joints from coming together all the way,, I see you put wood filler in all the joints..if you are going to paint it , should be just fine
It's hard to tell from a picture, but I can't think of anything else ,unless the T & G bit set you use is not set right but you said you did a dry fit and it was ok,, it's best to cut the panel a little smaller than it needs to be,,that way you have a place for the glue to go..if you have too much in the joint,,
Plywood is funny stuff,, it will splitter easy if it gets into a jam..so to say it's best to sand the edges b/4 you put it into place..so it can just slide in easy..
post #6 of 12 (permalink) Old 03-23-2009, 06:00 PM
Ghidrah's Avatar
First Name: Ronald
Were they butt, half lap or mortises joints?
Most of the time for mortises it's debris in the hole usually from splintering an edge.
Tricks I use to keep myself honest, I got tired of said errors a long time ago. They still occur, but are much rare and most times only occur while rushing.
1. Use stops when cutting matching stock.
2. Check your miter box, slide and or panel board regularly for square and or parallel.
3. Witness marks for orientation and position, Aa, Bb, Cc, etc., and strikes. These help during dry fit and glue up, I tend to put the blinders on when I'm in the glue up stage and rely on the marks.
4. Clamp during dry fit. Sound like a waste of time? Not if the length of matching stock doesn't. Dry clamp shows length and square errors.
P.S.
Bobj3,
No loose joints on the water. I'd assume dry fit included the panel, I only see filler on one end
Ghidrah is offline
post #7 of 12 (permalink) Old 03-23-2009, 06:32 PM Thread Starter
Yes, I included the panel, Everything went together ok, Now that I have had time to think about it most likely was the glue. (If a little bit is good, a whole lot is better) cut panel smaller, Well like I said I have come up with about 40 ways I could have done better! Not un-happy with it, My friend was tickled silly about it Thanks to all John
jbishop is offline
post #8 of 12 (permalink) Old 03-23-2009, 07:50 PM
Hi Ghidrah
" I only see filler on one end "
Take a hard look at it,, but it's fine the way it is..but it's hard to hide filler in Oak....
P.S.
Bobj3,
Name:	door filer.jpg
post #9 of 12 (permalink) Old 03-23-2009, 09:09 PM Thread Starter
Thanks Guys, I need to slow down, But still happy with my first attempt! My friend will be using a stain that should hide the filler, and a marine poly to seal. John
jbishop is offline
post #10 of 12 (permalink) Old 03-23-2009, 11:32 PM
Barry99's Avatar
First Name: Barry
Did you measure ends diagally to see if square?
Barry
~Is it measure twice and cut once, or cut twice and measure once?~
Barry99 is offline
Hello stephan New Member Introductions 7 10-17-2011 01:40 PM
Wanted: Looking for glue pot bobj3 Woodworking Classifieds 16 03-30-2009 07:46 AM
Glue Ups 1x4 x 24 3putt Lobby 5 12-29-2008 02:21 PM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
