Jessem Clear cut TS stock guides - Router Forums
 7Likes
post #1 of 13 (permalink) Old 04-24-2018, 05:48 PM Thread Starter
Default Jessem Clear cut TS stock guides
I have a Bosch 4100 table saw. I am thinking about getting the Jessem TS guides but I can't find anything which covers compatibility issues. I have searched but not found anything addressing this . Has anyone installed the guides on a 4100 and if so are there any issues or problems I need to be aware of?
billyjim is offline
post #2 of 13 (permalink) Old 04-24-2018, 06:24 PM
First Name: Richard
Call Jessem and ask them.
Ray Newman likes this.
Shop guy is offline
post #3 of 13 (permalink) Old 04-25-2018, 08:45 AM Thread Starter
I had considered that but I was hoping for some firsthand experience with the guides on the 4100.
billyjim is offline
post #4 of 13 (permalink) Old 04-25-2018, 11:00 AM
Get the Jessem product guide here: http://jessem.com/assets/04301---cle...ock-guides.pdf
Looks to me like the problem will be attaching the wide base of the guide to the narrow top of your fence. You could make an add on fence that fits over the Bosch fence, on which you'd mount the Jessem unit. This modification could bolt onto the Bosch fence, but will add bulk and take up a couple of extra inches of cut width. For ripping most stock, that wouldn't be much of a loss.
Illustration. I've made a quick drawing of what I'm talking about. Make certain your blade is an exact 90 or this won't fit quite righ or square. The knurled knob lets you tighten this to the fence. The little spacer blocks will help seat this properly. I'd make the face with 3/4 BB ply. Personally, I'd make the spacer blocks go all the way to the top of the auxiliary fence to stiffen the structure a bit. I would not use a solid piece for this to run the full length of the fence. I'd run the knob through one of these spacer blocks and leave about an eighth of an inch for the Bosch fence. I'd put in two or three knobs to hold the fence solidly in place.
Make the top fence piece wide enough for the guide to mount. I'd either assemble the aux. fence using dados, or use screws and glue.
I like the look of the guides and see why you'd want them. My only consideration would be whether they got in the way of my Grrripper or push stick.
Name:	Bosch Fence add on.jpg
post #5 of 13 (permalink) Old 04-25-2018, 12:28 PM
[QUOTE=DesertRatTom;1906537]Get the Jessem product guide here: http://jessem.com/assets/04301---cle...ock-guides.pdf
Your drawing is not a good representation of the Bosch fence.
The top of the fence has a 1/2"X7/8" "T" slot it.
If the jessem mounting bar is wider than 1/2" the end cap can be removed and the mounting bar can be slid onto the top of the fence, then replace the end cap.
https://www.amazon.com/JessEm-4301-C...ble+Saw+guides
But I would call Jessem to make sure.
A person could always rip a wood filler to slide into the "T" slot and mount the Jessem on top very easily
Name:	Bosch Fence.JPG
Herb Stoops is online now
post #6 of 13 (permalink) Old 04-25-2018, 03:17 PM
Herb, don't have one so it is just a representation. Looked at the guide mounting bar and it is fairly wide. I'm sure you could modify the bar to work, but I'm not inclined to modify items I might want to return. Still best to contact Jessem about this . The accessory fence is pretty much a standard jig, but usually with a tall front fence.
post #7 of 13 (permalink) Old 04-25-2018, 05:07 PM
Sorry Tom, I misunderstood, I thought you had one, Your right about not wanting to modify the mount. If I was mounting one, and it was wider than the T slot, I would rip a piece of hardwood and attach it to the top of the fence ,then mount the Jessem guides to that.
I have the jessem guides that mount on my router table. They work very well and I don't need feather boards. Wish I could use them on the table saw.
Gaffboat and DesertRatTom like this.
post #8 of 13 (permalink) Old 04-26-2018, 12:11 AM
It's a nice gadget, but I still would not want to stop using my Grrripper and I can't see how you'd do that. Any ideas?
post #9 of 13 (permalink) Old 04-26-2018, 08:50 AM
CharleyL's Avatar
First Name: Charley
I once had a pair of Board Buddies, a kind of different version of the Jessum Clear Cut, and I sold them because I couldn't use them with my Micro Jig Grrippers. The most often used method of using the Grrippers is to position them against the fence on top of your board and then push the board along the fence and through the saw. When feeding long boards, I use two Grrippers and do a hand over hand method of feeding the board through the saw. I just felt that I preferred this method to the Board Buddies and never used them after getting the Grrippers.
Charley
DesertRatTom likes this.
Central North Carolina
CharleyL is offline
post #10 of 13 (permalink) Old 04-26-2018, 09:24 AM
Charley
Same here on the Grrippers. I think they're surely the number one safety item for woodworkers.
CharleyL likes this.
Looking at the JESSEM Clear-Cut Precision Stock Guides, JessEm# 04215 dcrusoe Table-mounted Routing 6 12-19-2015 07:42 PM
Jessem stock guides RainMan 2.0 Table-mounted Routing 18 08-26-2015 04:42 PM
JessEm Clear-Cut Stock Guide: Best Deal! mlwinnig Table-mounted Routing 14 01-12-2015 05:08 AM
jessem clear cut stock guides Peteroo Table-mounted Routing 4 05-05-2014 08:40 AM
JessEm Stock Guides PRDarnell Table-mounted Routing 5 08-04-2013 09:56 PM
