your thoughts on titebond glue - Router Forums
post #1 of 15 (permalink) Old 03-24-2009, 02:29 PM Thread Starter
levon's Avatar
First Name: levon
Default your thoughts on titebond glue
i normally use titebond II yellow glue. if i was building something to go outside i might use the titebond III. but for inside i think the titebond II is good enough and for a tight old guy like me, its a lot cheaper.
also how long do you leave your glueups?
i have taken them apart after 30 minutes, but if im really concerned, i will leave it overnight.
what are your thoughts?
levon
levon is offline
post #2 of 15 (permalink) Old 03-24-2009, 02:33 PM
I use II and III. The II is on the yellow side and the III is a lot darker when dried. I too leave everything clamped over night. Don't know why.. just do. I've got to try the 50/50solution on the glue that squeezes out to see if the wood will still take a stain without a glue mark.
Greeneyedeagle is offline
post #3 of 15 (permalink) Old 03-24-2009, 02:35 PM
Bob N's Avatar
First Name: Bob
levon,
TBII is fine for indoor projects. I use Elmer's Wood Glue with great success myself and is a tad cheaper.
Usually leave the clamps on for about and hour for good measure and then let it cure overnight before adding any stress to the joint at all.
Hope this helps and can't wait to see your projects.
Bob N is offline
post #4 of 15 (permalink) Old 03-24-2009, 02:37 PM Thread Starter
levon's Avatar
First Name: levon
hi Palmer,
what i like about the 50/50 solution is that when you wipe it off you can tell its cleaning it off and not smearing it like when you wipe it of with a rag soaked with water.
levon
levon is offline
post #5 of 15 (permalink) Old 03-24-2009, 02:43 PM
dovetail_65's Avatar
First Name: Dovetail
Titebond III is the SH**. I use nothing else anymore. The pennies saved are not worth getting more than one glue type for me personally.
Titebond III needs only be clamped for 30 minutes max and you can continue on with the project. The next day if you try to break the glue line it will not, the wood will crack before the glue line tears apart and that is clamping 20 - 30 minutes, anything else is wasted time when using Titebond III. I have wasted so much time until I talked to Franklin reps and did what they said(clamp only 20-30 min)and yes 30 minutes is all the clamping time it takes.
Titebond III performs better than epoxy, cleans up with water, is water proof and I have made countless inlays that have sat out on decks for years with no de-lamination from the weather or floor traffic. I swear by the Titebond III.
dovetail_65 is offline
post #6 of 15 (permalink) Old 03-24-2009, 02:44 PM Thread Starter
levon's Avatar
First Name: levon
Originally Posted by Bob View Post
levon,
hi Bob,
i wanted to post you a message earlier, but knew how busy you were. around here i havent seen Elmer's wood Glue but when i get up that way, i will try it.
Have you started on the ski's yet? i have done the glueup for the ends.
but after i get the ski jig, i have to work on the template base or holder.
levon
levon is offline
post #7 of 15 (permalink) Old 03-24-2009, 02:52 PM
Bob N's Avatar
First Name: Bob
levon,
I have not actually started the skis yet, but trying to gather the info to purchase the parts and supplies I will need.
Bob N is offline
post #8 of 15 (permalink) Old 03-24-2009, 03:04 PM Thread Starter
levon's Avatar
First Name: levon
hello Nick,
its good to see you on here. i guess its cause im cheap i use the tbII.
if i was making a living like you doing this, im sure i would use the titebond III also.
levon
levon is offline
post #9 of 15 (permalink) Old 03-24-2009, 03:07 PM Thread Starter
levon's Avatar
First Name: levon
Bob, if i can get a little more accomplished i will try to post a few pictures but am going about it slow.my work has hindered my hobby, isnt that a shame?
levon
levon is offline
post #10 of 15 (permalink) Old 03-24-2009, 03:39 PM
Ralph Barker's Avatar
First Name: Ralph
Another TBIII fan here. I particularly like the lower chalk point and the longer open time.
- Ralph
Ralph Barker is offline
Hello stephan New Member Introductions 7 10-17-2011 01:40 PM
Wanted: Looking for glue pot bobj3 Woodworking Classifieds 16 03-30-2009 07:46 AM
Glue stain on maple & cherry? Bogydave Tools and Woodworking 13 01-21-2009 02:36 PM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
