ZC Insert for 45's - Router Forums
post #1 of 6 (permalink) Old 03-24-2009, 10:22 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Default ZC Insert for 45's
For straight cuts with my table saw I have a home made Zero Clearance Insert which is 4x 11 (see photo).
I never had the need to do any cuts with my saw at 45 degrees and now I need to do some.
I wonder how you make a ZC insert for such a cut. Do you just put a blank insert and raise the blade slowly until she comes thru the blank insert?
Thank you
Nicolas
kolias is offline
post #2 of 6 (permalink) Old 03-24-2009, 11:01 PM
Ghidrah's Avatar
First Name: Ronald
I have a 90 zero clearance insert that I never use. The table seemed to accumulate more chips and dust than with the standard insert.
As for making one for 45 this means you'll have to lower the blade before turning it over to 45 then raise it up.
Sounds too much like work.
Ghidrah is offline
post #3 of 6 (permalink) Old 03-25-2009, 12:25 AM
HI Nicolas
That's a no no most of the time
Just use the insert that came with the saw..
You need to think about that one,,as the blade is laid over it needs more room to spin free...so the ZCI is just a wast of time on a 45 deg.cut.
Thank you
Nicolas
post #4 of 6 (permalink) Old 03-25-2009, 01:19 AM
Ralph Barker's Avatar
First Name: Ralph
The problem is that the tilt and blade elevation mechanisms are separate. The elevation mechanism raises the blade at 90, whereas the tilt mechanism tilts from that position. Thus, there's no way to raise the blade along the angle.
- Ralph
Ralph Barker is offline
post #5 of 6 (permalink) Old 03-25-2009, 07:30 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you
kolias is offline
post #6 of 6 (permalink) Old 03-25-2009, 09:50 AM
AxlMyk's Avatar
Well, not exactly. Mine will raise on the 45 in order to cut a ZCI for that angle. But, as Bj said, why bother. I use the wide slot insert that came with the saw.
AxlMyk is offline
guide to making zero clearance inserts ZCI blurry Tools and Woodworking 12 03-01-2009 11:13 PM
Bench dog Pro lift template guide insert Ghidrah Guide Bushings and Templates 1 02-22-2009 02:48 PM
ZC Insert kolias Tools and Woodworking 7 01-01-2009 10:17 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
rousseau table insert 46_trap Table-mounted Routing 6 07-06-2007 09:33 PM
