Crosscut sled? - Router Forums
post #1 of 11 (permalink) Old 03-26-2009, 04:34 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Crosscut sled?
Why we call it crosscut sled? canít you rip a piece if it fits inside the sled?
Thank you
Nicolas
kolias is offline
post #2 of 11 (permalink) Old 03-26-2009, 05:38 PM
I'm gonna guess it was because the original intent of the inventor was to make it easier and safer to cross cut boards and panels before the advent of the "chop" saw, or the radial arm saw. But I've been wrong once or twice before!
a1tomo is offline
post #3 of 11 (permalink) Old 03-26-2009, 06:53 PM
Hamlin's Avatar
First Name: Ken
Because, the norm, you cut across the grain. You rip cut with the grain. This is why you have crosscut and rip blades.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 11 (permalink) Old 03-26-2009, 08:42 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you Ken
I know about across the grain / with the grain etc. But can you put a piece inside the sled and cut with the grain? Is there any safety issue?
Nicolas
kolias is offline
post #5 of 11 (permalink) Old 03-26-2009, 08:49 PM
Hamlin's Avatar
First Name: Ken
Hi Nicholas,
To answer your first question, yes. Second question, yes.
The difference is, the cut. You get a better cut with a rip blade if you're ripping. Same with a cross cut blade for cross cutting. If you intend on doing both, best to get yourself a combo blade. I have a freud thin kerf combo and this blade just rocks!!
Ken
"A VETERAN"
Hamlin is offline
post #6 of 11 (permalink) Old 03-26-2009, 08:53 PM
curiousgeorge's Avatar
First Name: George
Originally Posted by kolias View Post
Thank you Ken
Nicolas
Yes! There is a safety issue making a rip cut with a cross cut sled.
It's called a cross cut sled because that is what it is intended for. Not rip cuts. Other wise it would be called a rip cut sled.
Rip cuts should only be made using the fence of your saw, that is, unless you enjoy having the wood thrown back in your face. Also, the fence should never be used when making cross cuts for the very same reason. Safety!
Can you say kick-back?
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #7 of 11 (permalink) Old 03-26-2009, 08:54 PM
AxlMyk's Avatar
There are sleds for ripping. Generally they are used to make tapers, such as table legs. They are usually called taper jigs.
AxlMyk is offline
post #8 of 11 (permalink) Old 03-26-2009, 09:03 PM
Hamlin's Avatar
First Name: Ken
Thanks George, I do stand corrected. I've seen many sleds have clamps that helped hold the piece in place.
Ken
"A VETERAN"
Hamlin is offline
post #9 of 11 (permalink) Old 03-26-2009, 09:50 PM
First Name: George
That is correct, Mike. They are not cross cut sleds, but a specialty sled made for that one purpose (taper jig) just as the cross cut sled is for a specific purpose (cross cut).
Ken, I agree there are some cross cut sleds with hold downs that could be used for holding a piece to rip cut. But, look at it this way; most rip cuts are for making a board a specific, measured width that you want to be exactly parallel to the opposite edge. Without using the fence to insure the equal width of cut, IMHO, you are just pis...., er, wasting your time.
George
Fort Worth, Texas
post #10 of 11 (permalink) Old 03-26-2009, 10:22 PM
dovetail_65's Avatar
First Name: Dovetail
I use a sled to rip cut one edge(usually the bark edge) off a piece of lumber with nothing touching the fence. In essence if you do this you just jointed one edge of the piece of wood.
Then I place that cut edge against the saws fence and cut. The two sides become perfectly parallel. I can use this same sled as a tapering jig also as I can move the angle of the sled's fence.
The difference between the cross cut sled and a sled for ripping is the orientation of the sleds fence system. A cross cut sled can only hold a piece so long and unless the fence is able to move parallel to the cut it gets unsafe as the piece gets longer.
A Cross Cut sled has a fence perpendicular to the blade.
A rip sled has a fence parallel to the blade.
A Tapering jig has a fence on an angle(but closer to parallel with the blade than perpendicular to the blade).
A Miter sled has a fence on an angle(but closer to perpendicular with the blade).
I have one of each of these plus a sled for only 45 degrees.
dovetail_65 is offline
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
Saw Table Crosscut sled Tale Gunner Jigs and Fixtures 1 06-28-2008 12:41 AM
Crosscut sled assembly video tileart Jigs and Fixtures 1 09-04-2007 09:10 PM
Crosscut sled - diffefent way to make it simplenik Tools and Woodworking 8 05-29-2007 09:02 AM
My Crosscut sled project Birch Jigs and Fixtures 5 03-30-2007 06:08 PM
