Table saw maintenance - Router Forums
 39Likes
post #1 of 62 (permalink) Old 05-01-2018, 09:05 PM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Default Table saw maintenance
Noticed my table saw blade mechanism was harder than normal to lower today, like I was cranking through resistance. Looked underneath it and saw a lot of sawdust buildup on the mechanisms. I’m thinking this is what I felt, the gears cranking through excess caked on dust. So I’m going to clean all this off and see if it helps. My question is what do I lubricate the gears with? Do I use anything at all? It seems this will just make dust stick to it even more.
Duane Bledsoe is offline
post #2 of 62 (permalink) Old 05-01-2018, 09:37 PM
dry lube such as TriFlow...
it doesn't collect dust and makes for a non-stick surface...
years and years of VOE says this works...
VOE says WD is a mistake and all myth... it's a wet something or another that attracts all kinds of trash... does way more harm than good in the scheme of things... I've made a lot of money cleaning/fixing/replacing/repairing after the fact...
It makes for a humongous mess [remember this come finishing time] and if it gets into an electric motor kiss the motor goodbye... It's also prone to flash fire and really doesn't work all that well on anything but it's convenient...
I'm real partial to Triflow but most any dry lube will work well providing it's has Teflon/PFTE in it... [higher percentage by volume is more gooder]...
CRC, Tiolube, KG and DuPont each have several most excellent industrial spec DRY SOLID FILM lubricants..
Criteria - dries dry to the touch, high pressure load bearing, contains Teflon/PFTE, barrier forming, extreme temperature range, [usually -100 to +500F] isn't hygroscopic, does not collect dirt, not flammable in dry state, chemical resistant, does not contain silicone, has a long list of compatibles and is really very long lasting... or any of or all the features WD hasn't got any of....
one thing about dry solid film lubricants is that when you apply them and you think that you didn't apply enough you have probably applied too much..
very, very little goes a loooooooooooooooong way...
Just wait until you do your saw's arbor mechanism w/ dry lube.. you and your saw will never be the same... You'll treat everything that moves in the shop in short order... Please thoroughly clean whatever before lubing..
It's a great release agent too...
Dry Film Lubricants are high performance coatings made up of very fine particles of lubricating agents blended with binders and other special additives. Once cured, these lubricating agents bond to the part surface as a solid film which reduces galling, seizing and fretting and protects against corrosion. Through the combination of these properties, dry film lubricants greatly improve the wear life of coated parts.
Dry film/solid film lubricants allow for operating pressures above the load-bearing capacity of normal greases and oils. They are also less prone to collecting soil particulates than greases and oils. In some applications, the coating is self-burnishing, leading to improved, rather than decreased, performance over time. Some blends of dry film/solid film lubricants are also temperature and chemical resistant allowing for their use in harsh environments such as jet engines where exposure to aviation fuel and extreme temperatures are the norm.
radios, JFPNCM, OPG3 and 8 others like this.
post #3 of 62 (permalink) Old 05-01-2018, 09:54 PM Thread Starter
First Name: Duane
Ok I’m sold. Where do I get it? Lowe’s have it?
post #4 of 62 (permalink) Old 05-01-2018, 09:58 PM Thread Starter
First Name: Duane
Looks like I can get it on Walmart’s website for che
post #5 of 62 (permalink) Old 05-01-2018, 10:24 PM
most everybody has it... or similar...
post #6 of 62 (permalink) Old 05-02-2018, 07:03 AM
difalkner's Avatar
First Name: David
Dry lube all the way, like Stick says. I use Blaster from Lowe's - works great!
David
JFPNCM, MEBCWD, Shop guy and 2 others like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 62 (permalink) Old 05-02-2018, 07:43 AM
WD40 stands for Water Displacer 40th attempt. Displacing water in, for example, the electrical connector between truck and trailer on snowy slushy days. All the log truck drivers up here keep a can in the cab. That is what it’s really good for.
One way to clean the threads is to wrap a cord around the screw and spin it from one end to the other if you can get at it.
OPG3 likes this.
post #8 of 62 (permalink) Old 05-02-2018, 07:53 AM
First Name: Richard
I also use Blaster and it works really well. A little dab will do you.
difalkner, MEBCWD and Stick486 like this.
Shop guy is offline
post #9 of 62 (permalink) Old 05-02-2018, 09:24 AM
OPG3's Avatar
First Name: Otis
I have used PB Blaster - it works great, but the smell is atrocious!
I use DuPont's Teflon product that Stick listed above and that stuff is great.
It is the best thing going for squeaky garage doors/tracks.
Stick's info is SPOT-ON!
OPG3
Tweak everything!
OPG3 is offline
post #10 of 62 (permalink) Old 05-02-2018, 11:10 AM
You can find Tri-Flow or its equivalent in almost any bike shop. Ask for dry chain lubricant.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 06:41 PM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Incra table top arrived , now the fabrication part RainMan 2.0 Table-mounted Routing 9 08-12-2014 10:21 PM
Your wisdom is sought gcodom Table-mounted Routing 8 12-10-2010 07:03 AM
