Circle Template? - Router Forums
post #1 of 9 (permalink) Old 03-27-2009, 11:24 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Circle Template?
The attached photo is from a template bobj3 made.
Im curious why the 3/4 guide is used and not a smaller one. Perhaps there is a reason and that is the purpose of my question.
If you were to cut a circle, I would think that you would like to use a small bit like 1/4 or 3/8 with the corresponding size guide.
Thank you
Nicolas
Name:	Circle Template.JPG
kolias is offline
post #2 of 9 (permalink) Old 03-27-2009, 11:39 AM
levon's Avatar
First Name: levon
hi Kolias,
i made one, the 3/4 hole for the guide is so you can use a 3/8 or 1/2 inch straight cutting bit. it makes the router stable and is just for holding the router in place. but Bobj can help you more. it works great, you will be glad you built it.
levon
levon is offline
post #3 of 9 (permalink) Old 03-27-2009, 12:08 PM
dutchman 46's Avatar
First Name: Howard
Question
Hello Nicolas
I can only make a guess. The 3/4 in. bit can be used to shave the excess off. Due to the larger circumference, it will leave a much smoother cut than a 1/4 in. bit. If you were cutting a thin material, you could cut it with the smaller bit. Bobj3 will have to affirm what i have said. Yes, I have been wrong before
John 3:16
dutchman 46 is offline
post #4 of 9 (permalink) Old 03-27-2009, 12:24 PM
First Name: Howard
here is another, i did not get to see the whole thing, Hope this helps, Free
John 3:16
post #5 of 9 (permalink) Old 03-27-2009, 12:53 PM
HI Nicolas
The bigger the hole the better,, if you have your router setup to take on the 1 1/2" it's the best way to go if not the 3/4" or the 1" will do just fine,,,in that way you can use many bits,, like a plunge router over for just one of them..to do both jobs at one time so to speak..
But you want the hole as big as you can get it so the chips can get out of the hole easy>>> the size of bit can be just about anything you want to use..with just a little bit of setup time you are set to just drop it in and make the cut...you can also put a nice ring or two on the outside edge of the circle...
The guide is the key on this jig..
By the way once you crank the speed up you can use a 1/4" but I don't recommend it ,,now for thin stock you will not have that error,the slot likes to fill up with chips and the bigger bit will have less jammed in the slot,,to recut over and over, not to say anything about the heat, heat kills router bits...
Thank you
Nicolas
post #6 of 9 (permalink) Old 03-27-2009, 01:54 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Excellent info bobj3 and Im glad I asked
I thought it would have been a stupid question but somehow I knew there was a reason.
Thanks again for sharing your experience
Nicolas
kolias is offline
post #7 of 9 (permalink) Old 03-27-2009, 03:13 PM
AxlMyk's Avatar
Originally Posted by dutchman 46 View Post
Hello Nicolas
The guide bushing is 3/4", not the bit.
AxlMyk is offline
post #8 of 9 (permalink) Old 03-28-2009, 01:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Nicolas, an important reason to use a large template guide whenever possible is that you are able to SEE the cutter, in addition, the sawdust (cutter dust!) does not tend to compress and increase the cutter temperature this is of course in addition to the fact that a variety of cutters can be used to put a fancy edge to the circle. Given time, I'm sure that I could remember even more reasons!
Harry
harrysin is offline
post #9 of 9 (permalink) Old 03-28-2009, 07:23 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Another few good reasons
Thanks Harry
Nicolas
kolias is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
Template Routing FlyFAmerica Portable Routing 11 12-21-2008 12:36 PM
Hitachi M12V template guides? vwmowery General Routing 6 08-31-2006 11:51 PM
Template, how to make? smacmullin Jigs and Fixtures 2 11-08-2005 04:52 PM
