I need some opinions/thoughts - Router Forums
 8Likes
post #1 of 14 (permalink) Old 05-07-2018, 11:11 AM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default I need some opinions/thoughts
I built a pool side box of Cyprus for daughter #2
It is currently about 800 miles from me at the moment so the following is my recollection. 39"w x 35"d x 36" h.
3/4" slat sides that are mortised into the four legs. 3/4 " thick slats x 6" tall. Full thickness mortise x 1/2 to 1" deep legs are approx 2" square.
top & bottom rails are pocket screwed into legs. Has 5 hinges from Rockler that are "anti-slam " type
Lid-Stay Torsion Hinge Lid Supports, Rustic Bronze Finish
50# per hinge b/c the leverage of the top is so great & the focal point is so far back the top becomes front heavy
The PROBLEM:
when you raise/lower the lid the top back rail twists. Torques.
Possible solutions:
(a) mortise the back upper rail into the legs
(b) somehow connive/obtain a different setup that will slowly allow the top to close.
Questions:
Can I mortise the upper rail into the rear legs w/o breaking the cheeks of the mortise. How thick should the tenon be & how deep into the 2" square leg can I make it? to avoid twisting.
Must I make the legs 3x3, 4x4
Any & all recommendations appreciated
thks
smitty
smitty10101 is offline
post #2 of 14 (permalink) Old 05-07-2018, 12:29 PM
A picture would sure help, you did a good job describing it, tho. Those hinges are not cheap. Can you add some vertical pieces either inside or outside to tie the slats on the back of the bin together at the hinges? Maybe too heavy of hinges? when you are lifting or closing do you put extra pressure on the hinges,working against the hinge restraint causing the hinge to exert a twisting force to the top rail? Will the lid close by itself if it is left alone to do so, if not you have too strong hinges. A size lighter hinge might help.
jj777746 likes this.
Herb Stoops is online now
post #3 of 14 (permalink) Old 05-08-2018, 09:46 AM
First Name: Gary
Smitty, Sounds like there is so much torque exerted to the (3/4") top rail that it is bowing the top rail outward (at the center) when closing...and bowing the top rail inward (at the center) when opening. If that is the case, can it be beefed up by adding more structure to the inside or outside to keep it from bowing?
gmercer_48083 is offline
post #4 of 14 (permalink) Old 05-08-2018, 10:06 AM
vchiarelli's Avatar
First Name: Vince
Smitty - I'm not sure how your slats are attached to the top and bottom rails, but I'll guess that since your slats are mortised into the legs, they are not attached to the rails??? Correct me if I'm wrong, but a picture would sure help.
Anyway, not sure why you would have used 5 hinges - I'm wondering if the hinges are fighting against each other. In this thread of my blanket chest/toy box I used different hinges that stay open (to prevent the lid slamming on little fingers). I only used two, one at each end, with a piano hinge attaching the lid to the back of the box. I realize that I have raised panels for the sides/front but that shouldn't matter to what you did. Here's a link for the hinges from Lee Valley but I got mine at Home Depot for less money.
My blanket chest thread: http://www.routerforums.com/show-n-t...tml#post654794
Lee Valley Hinges: Lid Supports - Lee Valley Tools
Herb Stoops and jj777746 like this.
vchiarelli is offline
post #5 of 14 (permalink) Old 05-08-2018, 12:15 PM
JOAT's Avatar
First Name: Theo
I have problems getting 2 hinges right, and you used 5? Really? Even a military footlocker only has 2. I would have done it different. Two regular hinges, and a chain to prevent the lid from going too far back. Either that or just a lift off lid. I like to keep things simple, at times, especially things like boxes and chests.
As for toy boxes, I do not like lids on them at all. This eliminates the possibility of a lid slamming on fingers or a head. It prevents a kid climbing in, then having another kid shut the lid and sit on it. Plus a small kid often has trouble enough just putting toys in a toy box, let alone messing with a lid. Once a kid gets older it is simple enough to add a lid, so it can be used as a seat, either lift-off or hinged.
JOAT is offline
post #6 of 14 (permalink) Old 05-08-2018, 02:24 PM
are the slat mortises free, glued or mechanically fastened??
WTB your pocket screwed joints have loosened...
the hinges are not in sync for operating load/tension...
the lid was closed by pushing down on a corner and the the lid acted as a torquing lever against it's self...
post #7 of 14 (permalink) Old 05-08-2018, 02:38 PM
I had a trunk lid slam on my fingers once while I was working on it, Dang ...that hurt.
post #8 of 14 (permalink) Old 05-08-2018, 04:04 PM
vchiarelli's Avatar
First Name: Vince
Theo - agree that lids slamming on little fingers hurt a lot. The hinges I used on the toy box are designed to stay open at any angle and will not close without manual intervention. Now if a kid climbs in and another kid sits on the box, well, that's not an issue with the box, that's a case of bad parenting.
Stick -agreed. In my post I mentioned that I thought the hinges were fighting each other. Could be that one of those hinges isn't installed square, but again, I think the middle hinge, or possible the three middle hinges are exerting pressure against the rail when opening and closing. If one of the hinges isn't square, there's no way the lid can open squarely without bowing or racking.
Herb, at least you didn't climb in and have someone sit on the lid.
Herb Stoops likes this.
post #9 of 14 (permalink) Old 05-08-2018, 05:55 PM
"Herb, at least you didn't climb in and have someone sit on the lid."
-Vince
The days not over.
DaninVan is offline
post #10 of 14 (permalink) Old 05-08-2018, 08:13 PM
jj777746's Avatar
Remove all except the 2 outer hinges.Open & close lid then replace one hinge at a time,open & close test to see if the problem is caused by a hinge in the first place(initially)
vchiarelli and Herb Stoops like this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
