Truing an edge of an aluminum bar - Router Forums
 12Likes
post #1 of 17 (permalink) Old 05-07-2018, 07:26 PM Thread Starter
First Name: Orlando
Default Truing an edge of an aluminum bar
I need to true the edges of a 36" long x 1/2" thick x 1-1/2" wide 6061 Al bar. Before I find a machine shop, or someone that has a mill, can I safely take off no more than .002-.003 using my table saw saw with a non-ferrous blade? One side has a bow the other a cup, If so, what safety precautions do I need to take aside from the normal - full face shield, long sleeves, feather board, push stick, blade guard. Additionally my saw (Grizzly G0833P w/2HP) has anti-kickback pawls and a spreader. If not recommended, then I guess it's off to the machine shop. Thanks for your suggestions.
OBG65 is offline
post #2 of 17 (permalink) Old 05-07-2018, 07:44 PM
use your router...
https://www.toolstoday.com/t-Aluminu...luminum%20bits
post #3 of 17 (permalink) Old 05-07-2018, 09:38 PM Thread Starter
First Name: Orlando
Stick, in reading the pdf file, I have those clamps but would need to screw down the bar to a substrate in order to get the clamp on it and keep it from moving. The bar is only 1-1/2" wide so I don't know if the clamps would be functional in this case. Also, those cutters do not have a bearing on them. Thanks for the assist.
OBG65 is offline
post #4 of 17 (permalink) Old 05-07-2018, 09:40 PM
I have cut 1/4" T-6 aluminum on a table saw W/ my 80t X10" blade and also did a finish cut on a piece on the router table. I sure makes a mess of the shop with the aluminum shavings.
With a bowed piece like you you describe, you are going to have to clamp it to a straight edge to hold it while you cut it straight.
Also the type and temper of the aluminum has a whole lot to do with the machine ability. Type SO for example machines very poorly and will melt and weld itself to the cutter. An aircraft grade of t-6 is what I prefer. Some Aluminum requires stick wax or a solution of oil and water emulsified to offer coolant for machining. Band saws have to have metal cutting blades and they tend to plug up
Best do some research and learn about how to cut it, before you do it. https://duckduckgo.com/?q=machining+...b=v80-5&ia=web
Before you ruin a tool or hurt yourself.
hawkeye10 likes this.
Herb Stoops is offline
post #5 of 17 (permalink) Old 05-07-2018, 10:40 PM Thread Starter
First Name: Orlando
That's my thinking Herb. Think I'm going to find a machine shop or someone with a mill to do this for me..
Herb Stoops likes this.
OBG65 is offline
post #6 of 17 (permalink) Old 05-07-2018, 11:10 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
More information needed. 6061 comes in many variants
https://en.wikipedia.org/wiki/6061_aluminium_alloy
sunnybob is offline
post #7 of 17 (permalink) Old 05-08-2018, 01:53 AM
It'd probably be less expensive to simply but a new piece of stock. Isn't the Architectural extrusion stuff dead accurate?
Speedy Metals Information for 6061 Extruded Aluminum Bar
DaninVan is offline
post #8 of 17 (permalink) Old 05-08-2018, 01:58 AM
clamp the aluminum in the guide and use a collet or top bearing carbide trim bit...
post #9 of 17 (permalink) Old 05-08-2018, 09:18 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Whilst I have the greatest of respect for my friend Stick, and routing is my thing, I would not rout or use the table saw for such a long length of Aluminium, rather, I would use my compound mitre saw where the piece can be securely clamped using the built in clamp and preferably use an Aluminium cutting blade but a standard 80 tooth blade has always worked for me.
Herb Stoops and bryansong like this.
Harry
harrysin is offline
post #10 of 17 (permalink) Old 05-08-2018, 11:06 AM
I'd price and buy a dead flat, straight edge. A slight slip or glitch will pretty much ruin your shop made effort. Alternatively, I'd go with the machine shop, but I bet it will cost as much or more than a commercially made straightedge.
DaninVan and hawkeye10 like this.
Trimming wood edge banding Cherryville Chuck Table-mounted Routing 4 10-29-2016 07:09 PM
edge band clamping technique gav Tools and Woodworking 5 03-04-2012 05:42 AM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 01:36 PM
Finished bar pictures sergeantnic Show N' Tell 11 07-05-2010 10:50 PM
Need some bar ideas lablover Tools and Woodworking 1 07-08-2007 05:05 PM
