Band saw guide blocks - Router Forums
post #1 of 16 (permalink) Old 03-28-2009, 08:31 PM Thread Starter
AxlMyk's Avatar
Default Band saw guide blocks
Instead of getting cool blocks or ceramic guides, I have read about using hardwood blocks that you make yourself. Cheap is good.
I have also read about people soaking those wood blocks in mineral oil and microwaving them. OK, the oil is for lubrication, but why the MW?
AxlMyk is offline
post #2 of 16 (permalink) Old 03-28-2009, 09:03 PM
Bob N's Avatar
First Name: Bob
Mike,
This is one of those trick questions... Right?
Bob N is offline
post #3 of 16 (permalink) Old 03-28-2009, 09:19 PM Thread Starter
AxlMyk's Avatar
Nope.
I've also read that soaking the wood blocks in WD-40 works also.
Woodworking: Hardwood Bandsaw Guide Blocks - In the Woodshop
AxlMyk is offline
post #4 of 16 (permalink) Old 03-28-2009, 09:27 PM
Bob N's Avatar
First Name: Bob
That is some interesting info Mike. I am curious about the microwave part though.
I have rollers on my BS, but I think the blocks are a better option in the long run, especially with the smaller blades.
Bob N is offline
post #5 of 16 (permalink) Old 03-29-2009, 11:43 AM
GBM
First Name: Greg
I think they are using them like Croutons in their salad...or Bacon crumbs....
WD 40 is not a lubricant.... better to use something that is.
If you look at the torque tables... putting WD40 onto threads requires that the torque meter reading be increased in order to get the same pull down on the item being bolted down. I know that seems wrong.... but the engineers actually measure those things. When you put a lubricant on threads ( the standard is lightly oiled ) the torque required either stays the same ( if the substance is equivalent to oil ) or is reduced if it is slicker than standard oil in lubricating properties.
I think a naturally oily wood should be used.... lignum vitae, etc...and then oiled in addition.
GBM is offline
post #6 of 16 (permalink) Old 03-29-2009, 11:59 AM
Ralph Barker's Avatar
First Name: Ralph
My guess is that "nuking" the wooden blocks might "case-harden" them, that is to say, the cellular structure of the wood fiber is hardened and almost all moisture removed. The moisture could then replaced by the oil soak.
- Ralph
Ralph Barker is offline
post #7 of 16 (permalink) Old 03-29-2009, 01:24 PM Thread Starter
AxlMyk's Avatar
The WD-40 is to soak the blocks in, not the threads.
I made a few blocks out of walnut and put the ends in a small cap I sprayed WD-40 into. They soaked it up like a wick. I installed them on the saw and adjusted them right up to the blade. With the saw running I adjusted the guides forward to bury the blades in the blocks, and did a few test cuts.
Resawing a 4" piece made a straight line with no curve to the cut from top to bottom. Making circle cuts the blade held tight. The best part is there were no sparks like you might get from the steel guides.
AxlMyk is offline
post #8 of 16 (permalink) Old 03-29-2009, 02:43 PM
Ghidrah's Avatar
First Name: Ronald
I believe the MW is to remove moisture from the wood so that something else can take its place, like creating a sponge. Also the less moisture in the available sap means its more likely to stay put.
Still how often do you go thru cool blocks or ceramic guides?
Ghidrah is offline
post #9 of 16 (permalink) Old 03-29-2009, 03:13 PM
GBM
First Name: Greg
I was using the example of the threads because there are tables of comparisons available to show that WD40 is not a lubricant... so putting it on the wood blocks may be counter productive.... particularly if it washes away the natural oil of something like rosewood or lignum vitae.
When heating something which has moisture in it from the inside out... like a microwave does... instead of from the outside in...like a regular oven does... often causes the moisture to expand the substance or crush the cells... as with mica being turned into vermiculite.
The fact that something gets soaked up by the wood does not necessarily mean that after it is put against the blade that is constitutes a lubricant... so it may cause more heat instead of the assumed goal of less....
GBM is offline
post #10 of 16 (permalink) Old 03-29-2009, 04:21 PM
I,ve been told that WD-40 is more or less a dessicant. That is it will attract, or soak up moisture. The lubricating properties, I would guess, are probably nil or non-existant for use as cool blocks.
To further confuse the issue, I use corian blocks as supplied by the local woodworker store. I really don't know if these are any better or worse than anything else.
Ideally, the roller bearing type would seem to be the best (nothing rolls like a ball).
That a couple of cents worth!
a1tomo is offline
Makita RF1100, 1101, RD1100, 1101 Straight Guide markus General Routing 4 01-20-2009 11:46 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Circular Saw and router guide "Off-set" plate simplenik Tools and Woodworking 9 11-19-2007 10:20 AM
Porter-Cable template guide no where to be found jnam Portable Routing 5 07-21-2006 07:54 PM
Porter-Cable template guide no where to be found jnam Jigs and Fixtures 3 02-21-2006 07:15 AM
