Miter saw dust collection - Router Forums
 9Likes
post #1 of 17 (permalink) Old 05-15-2018, 04:48 PM Thread Starter
Marco's Avatar
Default Miter saw dust collection
Stumbled across this while looking for dust collection tools/parts for the shop... Dust Drag In
Dust Drag-in
Would love for it to work well. I am not picking up the dust off the sides of the blade.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #2 of 17 (permalink) Old 05-15-2018, 06:36 PM
First Name: Reuel
Dust Drag-in
Seems like a good design requiring no electricity.
Only about $30 so it is worth testing it out. Would be better than none.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #3 of 17 (permalink) Old 05-15-2018, 06:56 PM
vchiarelli's Avatar
First Name: Vince
@Marco - only problem I have with this is that the picture they show of "dust" is actually chips in the barrel. Don't get a lot of chips off the miter saw, so not sure how effective it is on actual dust coming off a miter saw.
vchiarelli is offline
post #4 of 17 (permalink) Old 05-15-2018, 09:48 PM
My miter saw has a dust port, but only about 2/3 of the dust/chips comes out the port, the rest blows out the sides and off the blade. That thing isn't going to do anything to capture the dust that doesn't come out the port.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #5 of 17 (permalink) Old 05-16-2018, 12:07 AM
Ok, looks interesting, but not much information--a new product. It doesn't seem like it will work on a sliding miter.
My solution helps a lot. I set up a U shaped structure above the saw and hung a clear shower curtain around the saw. There is just enough room for the saw to swing without impeding the slider bars. The shower curtain hangs down to the height of the saw motor and comes around the sides so that the majority of sawdust winds up back in the curtain. The curtain is gathered into a box with a 4 inch dust port. The top of the curtain is covered as well. I used aluminum duct tape to hold it together, which holds far better than I'd hoped.
As I used this, I discovered that cutting technique has a LOT to do with sawdust dispersion. To minimize that, I now make a very light cut across the top of the workpiece, then push the blade back and down. The first cut forms a channel that throws most sawdust back into the curtain.
Dramatically cuts flying sawdust. Next step is to take a small piece of aluminum and curve it into a U shape that fits on the built in 2.5 inch dust port. I'll affix the U shape just behind the fence so the sawdust will be directed into the port. Ample suction will catch allmost all sawdust coming off the saw.
This is constructed against a wall and I used two large L brackets to hang the curtain. Measured the width of the saw with it at both 45 degree settings. The table is on casters so I can pull it out a little for 90 degree cuts. I screwed a stop bar onto the floor to push the table back into storage position.
Sorry no detail. I had but can't locate a picture of this setup. Took an hour or so to put it together. There are many ways to do something like this, but this was an easy fix, and cheap too.
Marco and dirt_dobber like this.
post #6 of 17 (permalink) Old 05-16-2018, 02:36 AM
First Name: Reuel
Originally Posted by DesertRatTom View Post
Ok, looks interesting, but not much information--a new product. It doesn't seem like it will work on a sliding miter. .
I also thought it won't work with a SCMS (sliding compound mitre saw) but then saw this picture with a SCMS.
The chute of the SCMS is NOT connected to a DUSTY or Shopvac
So probably the dust shooting from the chute will create a flow and DRAG-IN the other dust - with the help of GRAVITY.
Best Regards
Reuel
reuelt is offline
post #7 of 17 (permalink) Old 05-16-2018, 06:02 AM
First Name: Rob
All I know is that the sliding miter saw in my shop is responsible for the majority of my mess.
I have found that some dust collection is better than no dust collection. Perfection is not achievable. Are some better than others? Oh yeah. But I don't have time to sort out the perfectly engineered solution for my particular saw. Too busy wasting wood and glue.
For $30 I am in. Anything is better than nothing.
I'll post some basic results once it arrives.
Rob
Tinman Carving is offline
post #8 of 17 (permalink) Old 05-16-2018, 06:20 AM
an extra large one of these laid over on it's side w/ a DC tap near either end..
use the lid to form additional hooding...
works rather well...
the more CFM the better..
10 ~ 15 dollars...
the hood pictured looks like it's more for non-slider saws...
DesertRatTom likes this.
post #9 of 17 (permalink) Old 05-16-2018, 10:13 AM
The picture shows it on a sliding miter, but the question to me is, does the slider rub against the tubing? I guess you could rig a little support sling to keep it elevated to avoid rubbing. I'd still rather have a little suction on it to feed into my DC setup.
post #10 of 17 (permalink) Old 05-16-2018, 10:55 AM
@DesertRatTom
I remember seeing a photo of your setup during an earlier discussion on this subject, and was intrigued but it seemed to take up more room than I have available, plus I also need something that is storable after I tuck my miter saw back under the bench where it lives. To go with your design though, there was an earlier thread that showed a gentleman making cabinets (for RV's?) on a production basis, and his miter saw pulled through one of those clear "ribbon-curtains" like one sees on a loading dock, albeit on a much smaller scale - that seemed to be a good idea to trap the sawdust that bounced back towards the operator. On your idea of the aluminum chute, I read an article where a piece of heavy (say 1/8" thick or better) was used to make a flexible chute to feed the discharge port on the guard - I saved a picture of the set-up (see below) but forgot to bookmark the article.
My miter saw is exactly that, an old Ryobi - what used to be called a chop saw I believe - now being used to replace my RAS for cutting narrower parts to length. I've played with dust collection on it; the Rockler plastic hood helps but needs side walls and a roof - maybe the roof could incorporate the ribbons hanging down? The drawback to this is the size - it has to be removed from the stand that the saw sits on and stored between uses. I haven't done much more on dust collection for that saw as I've been working on refurbishing one of the old (long out of production) Sears 7-1/2" miter saws that looks like a mini RAS and will probably concentrate on some type of dust collection system for it.
Name:	Miter Saw Dust Deflector.jpg
tomp913 is offline
Table saw sled with dust collection difalkner Jigs and Fixtures 11 12-02-2016 06:55 AM
Below table dust collection jonlruss Table-mounted Routing 6 09-08-2016 04:50 PM
Portable Dust Collection Cart with Noise Reduction & Dust Separator using Shop Vac pbriggs8 Project Plans and How To 5 05-18-2016 05:06 PM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
