RPM in Acrylic - Router Forums
post #1 of 13 (permalink) Old 03-30-2009, 08:02 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Default RPM in Acrylic
What RPM setting you will use to route a 2 x 8 slot on a 1/4 thick acrylic?
Any straight bit will do it?
What size bit you will recommend?
Any special precautions?
Thank you
Nicolas
kolias is offline
post #2 of 13 (permalink) Old 03-30-2009, 10:47 AM
i havent done a slot but i did an edge on .220 acrylic and just used the max rpm and it turned out fine
be aware that it will be real stinky!
Mike Gager is offline
post #3 of 13 (permalink) Old 03-30-2009, 11:13 PM
mountaindew's Avatar
First Name: Lane
Thank you
Nicolas
I would construct a pattern from 1/4" masonite of the 2x8 slot you want to make. then mark the 2x8 slot on acrylic. Then use a saber saw to cut 2x8 slot out staying away from edge about 1/4". Then double stick tape the masonite 2x8 template/pattern to acrylic along the marked edges and route the last 1/4" off to finished edge with a flush pattern bit with top bearing. You will end up with a nice smooth edge, no melting no problems.
i could post pics of doing this but i dont have enough posts yet
hth
mountaindew is offline
post #4 of 13 (permalink) Old 03-31-2009, 12:51 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you Lane for the info
I do have a pattern and your idea to cut off some of the acrylic with a saw it's a good one.
What RPM is your router set for the job? Did you use a straight bit or what?
Nicolas
kolias is offline
post #5 of 13 (permalink) Old 03-31-2009, 02:31 AM
derek willis's Avatar
First Name: Derek
I have done a lot of cutting and shaping of Acrylic, use high revs. and a spiral bit if possible, otherwise a two flute straight bit will do almost equally as well, a very good finish is obtainable on the cut adeges.
Derek
derek willis is offline
post #6 of 13 (permalink) Old 03-31-2009, 07:21 AM
AxlMyk's Avatar
All I know is that you can't use a metal shear to cut it. It explodes.
I actually tried that once.
AxlMyk is offline
post #7 of 13 (permalink) Old 03-31-2009, 08:37 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you for the help
Nicolas
kolias is offline
post #8 of 13 (permalink) Old 03-31-2009, 09:29 AM
Hi Nicolas
They make and sale router bits just for that job
Thank you
Nicolas
post #9 of 13 (permalink) Old 03-31-2009, 11:51 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Good to know bobj
Thank you
Nicolas
kolias is offline
post #10 of 13 (permalink) Old 03-31-2009, 12:50 PM
CanuckGal's Avatar
First Name: Deb
I cut both a 3/8" slot and 1" slot in 5/8" acrylic to make a guard for my bandsaw. I used the highest RPM's on my router and a double fluted 3/8" straight bit. The 3/8" slot was a through slot I made in 3 passes and the 1" slot was 3/16" deep and I made it in two passes each time moving the fence to get the final width.
These were not end to end slots so I had to drop the acrylic on the spinning bit. It was my first time routing acrylic so I may have been a little over cautious with the number of passes. Everything worked out just fine.
CanuckGal is offline
Another Acrylic pen "how to" harrysin Woodturning and Lathes 12 02-14-2012 01:34 AM
Routing Acrylic .... lemonyx General Routing 23 12-04-2009 01:00 AM
First Acrylic Pen Bob N Woodturning and Lathes 6 02-23-2009 07:47 AM
Acrylic routing problem marc.brunet.gagne General Routing 1 05-08-2008 01:04 PM
My first acrylic pen Glenmore Woodturning and Lathes 26 08-30-2007 10:34 PM
