Splines chipping out. - Router Forums
 24Likes
post #1 of 23 (permalink) Old 05-19-2018, 01:08 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Splines chipping out.
I built a small box and put splines in the mitered corners. Well, the splines are chipping out when I used a block plane to level the splines. The chip out is on the corners. I cut the walnut splines from a strip about 15" long and 1/8" thick and maybe 3/4" wide. I inserted the splines with the grain running from left to right. So how would I stop this so it won't happen again?
I was thinking about rounding the corners with a 1/8" bit to hide the chip out. What do you think about that?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 23 (permalink) Old 05-19-2018, 01:23 PM
It must be a lot of chip out if sanding it round isn’t enough. We’re you going towards the corner and chipped that tip off? If so go from the out side in at every corner.
Roy Drake, tomp913 and hawkeye10 like this.
post #3 of 23 (permalink) Old 05-19-2018, 01:54 PM
vchiarelli's Avatar
First Name: Vince
Agree with Chuck on the planing direction - if you plane from inside to outside, there is nothing to support the fibers as you plane, so plane from each corner to the middle of the spline and take a very light cut with your plane
hawkeye10 likes this.
vchiarelli is offline
post #4 of 23 (permalink) Old 05-19-2018, 02:07 PM
also ''sweep'' the plane through the spline...
Ray Newman and hawkeye10 like this.
post #5 of 23 (permalink) Old 05-19-2018, 05:39 PM Thread Starter
hawkeye10's Avatar
First Name: Don
I agree I did plane in the wrong direction. I bet if I had used a chisel I would have been better off. Hindsight is always 20-20.
post #6 of 23 (permalink) Old 05-19-2018, 07:27 PM
I generally use a thin Japanese pull saw to trim off splines, then a little light sandpaper work to smooth it out. I often use 1/8th purpleheart just for the contrast. It's one of those saws with no set on the teeth, so it doesn't mess up the box sides. Just be patient and don't rush it. The saw has incredibly fine teeth and no stiffener, so if you push it, it will bend.
JFPNCM, Roy Drake, tomp913 and 1 others like this.
post #7 of 23 (permalink) Old 05-19-2018, 11:03 PM
As with the plane or chisel, the pull saw still needs to cut from the outside towards the inside to prevent chipping. For a part I was trying hard to get right, I put a layer of blue tape on either side of the spline, used a flush-cut pull saw to get it close and then used the Veritas Flush Plane Veritas® Flush Plane - Lee Valley Tools - you still need to cut from the outside in, and use a sideways shearing cut to prevent any chip out. I'm making a box for my wife at the moment, will post a final photo if it turns out OK - forgot to take process photos to this point and all I hae left is fitting the lid and drilling for the hinge pin..
tomp913 is offline
post #8 of 23 (permalink) Old 05-20-2018, 04:44 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I just use a belt sander for any thing like that. I take off all excess with 60 grit which eats the wood away fast, then sand properly with 240
JFPNCM likes this.
sunnybob is offline
post #9 of 23 (permalink) Old 05-20-2018, 08:12 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Not me Bob, in my hands a belt sander spells disaster.
post #10 of 23 (permalink) Old 05-20-2018, 08:35 AM
plan ''B'' and ''C''???....
Splines for miters difalkner CNC Routing 11 08-28-2017 10:35 AM
Splines for chest corners billyjim Project Plans and How To 37 09-22-2014 12:30 AM
Making Bow Tie Splines (Not Inlays) damnitboy Tools and Woodworking 5 03-03-2012 01:04 PM
Making Bow Tie Splines (Not Inlays) damnitboy Jigs and Fixtures 6 03-03-2012 12:48 PM
How should I trim picture frame splines? lrr General Routing 4 02-11-2007 10:59 PM
