Setting Jointer Knives - Router Forums
 13Likes
post #1 of 11 (permalink) Old 06-07-2018, 09:59 AM Thread Starter
Default Setting Jointer Knives
Saw this, thought it might be of interest to someone looking for a(nother) way to set the knives on their jointer. I have one of the magnetic jigs, but this looked like a pretty slick way to get the job done.
https://www.woodmagazine.com/woodwor...wdm-newsletter
tomp913 is offline
post #2 of 11 (permalink) Old 06-07-2018, 10:04 AM
That is interesting, have to remember that.
MEBCWD and tomp913 like this.
Herb Stoops is offline
post #3 of 11 (permalink) Old 06-08-2018, 07:17 AM
First Name: Ron
That is pretty cool, I'll have to try it out, thanks.
tomp913 likes this.
ronheb454 is offline
post #4 of 11 (permalink) Old 06-08-2018, 07:59 AM
chessnut2's Avatar
I just did approximately the same thing, and it really works.
tomp913 likes this.
chessnut2 is offline
post #5 of 11 (permalink) Old 06-08-2018, 09:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
A very interesting idea, but remember that only the very thin tape must be used, not the foam type.
Harry
harrysin is offline
post #6 of 11 (permalink) Old 06-08-2018, 10:26 AM
I like this idea. I think I'd prefer to try it with Scotch Magic Tape, which is extremely thin. I'd fold over one end so I could easily peel it off.
harrysin and JFPNCM like this.
post #7 of 11 (permalink) Old 06-08-2018, 03:13 PM Thread Starter
I don't think that the article specified what type of tape to use, but I believe that I'd try electrical tape - it's thin, and an insulator, which is what you're looking for.
TwoSkies57 likes this.
tomp913 is offline
post #8 of 11 (permalink) Old 06-08-2018, 05:45 PM
I’ll have to try that. My current method is to lay a hardwood block on the out feed table and adjust it until the knives just touch it enough I can feel it.
post #9 of 11 (permalink) Old 06-09-2018, 09:07 AM
chessnut2's Avatar
To avoid having to insulate the bar, I made mine by screwing a piece of narrow aluminum bar to the edge of a straight oak 1 x 2, with the screw nearest the blades long enough to protrude above the 1 x 2. The protrusion gives you a metal surface to connect the ohm meter, or in my case, an automotive continuity light, to the aluminum bar.
Then I sawed a through slot across the aluminum bar about an inch from that screw so it would be isolated from the part of the bar that's contacting the bed. I was able to avoid having to shim with tape to insulate the bar that way.
post #10 of 11 (permalink) Old 06-09-2018, 09:18 AM
harrysin's Avatar
First Name: Harry
Electrical tape is on the thick side Charles, it will introduce a very slight error.
Harry
harrysin is offline
Grizzly G0490X 8" Jointer with Spiral Head Dejure Tool Reviews 11 01-17-2016 03:12 PM
Installing Jointer Knives on a DJ20 8" Delta Jointer TRN_Diesel Tools and Woodworking 9 06-23-2014 08:53 PM
Looking For Advise On 'Changing Knives On PC Bench jointer Jerry Bowen Tools and Woodworking 5 04-13-2012 11:53 AM
Setting Jointer knives jd99 Tools and Woodworking 13 10-28-2009 10:49 PM
Installing jointer knives - Help - Old 4" Joe Lyddon Tools and Woodworking 4 10-20-2007 10:54 AM
