Veritas Cyclone Lids? - Router Forums
post #1 of 10 (permalink) Old 07-31-2005, 04:00 AM Thread Starter
GoonMan's Avatar
First Name: Randy
Default Veritas Cyclone Lids?
Hello all,
Since I have ran across some extra rough wood in Pallets and crates I have been working my Rigid 13" Planer pretty hard along with my shop vac. I was wondering if anyone has used or tried the Veritas Cyclone Lids on a large trash can. Does it work as well as what is claimed in their catalogue?
GoonMan is offline
post #2 of 10 (permalink) Old 07-31-2005, 11:17 PM
reible's Avatar
Hi,
Can't say about the Veritas one or about hooking one up to a shop vac but I do have one that fits a trash can and hooks to my dust collector and it works. I don't remember where I ordered it but it was some years ago just after they first came out and it fits what I think might be a 30 gallon can??? Anyway it keeps bigger pieces from going any farther and gets most of the wood chip and best of all it easy to empty.
Hope this helps,
Ed
reible is offline
post #3 of 10 (permalink) Old 08-01-2005, 07:31 PM Thread Starter
GoonMan's Avatar
First Name: Randy
Thank you Ed,
GoonMan is offline
post #4 of 10 (permalink) Old 08-12-2005, 11:46 AM
Default homemade one works well
I made a cyclone lid out of a piece of plywood and some aluminium ductwork for a bathroom exhaust fan.Cut the ply a little bigger than the can opening.
Mount a straigt pice of duct through the center,and a piece with an elbow off to the side near the edge of the can.The center duct is where you hook up dust collector and the opening should be below the elbow of the outer duct.The duct with the elbow goes to yor machine.
This system works well for me and is cheap to build.
AKROPAUL is offline
post #5 of 10 (permalink) Old 08-12-2005, 02:14 PM Thread Starter
GoonMan's Avatar
First Name: Randy
Hello AKROPAUL, Welcome to the RouterForums
Thank you for the tip, would you happen to be able to post a picture of what this looks like. I have a general Ideal pictured in my head but seeing would help.
GoonMan is offline
post #6 of 10 (permalink) Old 08-13-2005, 01:13 PM
tman is offline
post #7 of 10 (permalink) Old 08-17-2005, 09:35 AM
Julie's Avatar
First Name: Julie
Hi Randy (you really should change that photo!)
I have the Veritas Cyclone Lid. I use it with my Shop Vac and hooked up to the planer. I have had success, but it doesn't take long to fill up the garbage can! I've also hooked it up to my jointer, but it just doesn't really have enough draw to use that way. It does also work well with the router in the table. I realise though that a dedicated dust collection system would be much better.
~Julie~
Julie is offline
post #8 of 10 (permalink) Old 08-20-2005, 03:10 PM
Default lid
Here is a way to make it you may like I have used it with much success.
http://www.woodcraft.com/articles.aspx?articleid=408
viper1 is offline
post #9 of 10 (permalink) Old 08-25-2005, 02:40 PM
Default Lee Valley Cyclone Lid
YES it certainly works!
I had built my own to use with my shop vac (2.5" pipe) and it certainly worked.
But when I bought a dust collector I decided that I really wanted a better Seperator, i.e. one that really makes most of the dust and chips settle in the Seperator Bin.
So I invested in the Clear Veritas Cyclone Lid from Lee Valley. It really made a difference. It is the 4" model and sits on a 50 Gallon drum. Hardly anything goes to the dust collector and it is great to see what is happening inside the drum through the clear lid.
It simply "sits" on the drum. It does not snap in place. I actually called LV to ask just how it is suppose to fit tightly and they told me that a "gravity" fit was all that was needed. This is true... I did use a strip of self-adhesive weather stripping around the barrel top to avoid any air escape... -CL
Chrislef is offline
post #10 of 10 (permalink) Old 08-26-2005, 07:52 AM Thread Starter
GoonMan's Avatar
First Name: Randy
Thanks all for the replies. I did order and received mine from Veritas yesterday, now I am anxious to give it a whirl.
Time for me too pick up some more crates and Pallets for the good free wood.
GoonMan is offline
veritas router insert Big Guy Lobby 12 02-28-2009 11:06 PM
Veritas router table 46_trap Table-mounted Routing 1 01-12-2007 09:29 PM
Veritas routing system RobertJR General Routing 3 05-23-2005 08:46 AM
Veritas By Leevalley Ryano Table-mounted Routing 4 05-05-2005 03:13 PM
