Plywood on fire - Router Forums
 12Likes
post #1 of 12 (permalink) Old 06-08-2018, 09:06 PM Thread Starter
Red Stick's Avatar
First Name: Keith
Default Plywood on fire
Today I was cutting 5/16 rabbits in 23/32 plywood on my router table. On the 3rd piece I noticed first a lot of smoke, then actual burning wood. Not exactly flames, but fire red. I shut off the router then shut off the dust collector. Was very concerned that the collector bag would suddenly erupt into flames so I as quickly as possible removed it from my dust collector. Emptied the bag and ran the dust collector to clear out any remaining embers. Seeing none I put the bag back into place and assumed the fire was out.
Since this was my third cut with all settings and feed rate the same, I assume there was just something weird in the plywood?
Anyone have any idea what happened?
Red Stick is offline
post #2 of 12 (permalink) Old 06-08-2018, 09:24 PM
off shore ply???
dull bit and sulfur content in the plywood or sparked by hitting metal in the ply.....
instead of sulfur there may be some other low flash point chemical present...
what did the smoke smell of???
when you cleared the system did you remove the bag??? sure hope so...
never ever assume the fire is out in saw dust... NEVER!!!
it can set for days and then start up w/o warning...
soak the snot out it and then drown the saw dust again several times...
suggest you treat the ply and saw dust to a strong magnet...
investigate this thoroughly....
you are now on fire watch till this is solved....
post #3 of 12 (permalink) Old 06-09-2018, 08:59 AM
First Name: Gary
I had that happen once routing mdf. Didn't have dust collection connected at the time, and was able to snuff it out with my shoe. A good lesson to have a fire extinguisher handy. When I was a Pup, years ago, where I worked, we had a 55gal drum out back with scraps of wood being burned from shelving being made on pallet racks. After sweeping up all the saw dust, I tossed the saw dust into the burning barrel...and to my surprise, it flashed...like gun powder. Never did that again!
DaninVan and Shop guy like this.
gmercer_48083 is offline
post #4 of 12 (permalink) Old 06-09-2018, 12:17 PM
MT Stringer's Avatar
I vote for dull bit.
radios, neville9999 and ksidwy like this.
MT Stringer is offline
post #5 of 12 (permalink) Old 06-09-2018, 12:32 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Ply is very tough on bits. Check the cutting edges, i reckon they will be dark brown or even black. throw it away
radios likes this.
sunnybob is offline
post #6 of 12 (permalink) Old 06-09-2018, 07:10 PM Thread Starter
Red Stick's Avatar
First Name: Keith
Default Thanks for replies
Thanks for the replies. Everything seems to be OK now. Maybe a dull bit, but it was the third cut and cut several more afterwards with no problem. Absolutely certain that any remaining embers were gone. This was pretty good birch ply but don't know the origin. Finished project looks very good! Thanks again for the replies.
MT Stringer and Roy Drake like this.
post #7 of 12 (permalink) Old 06-11-2018, 12:18 PM
First Name: Ralph
Send a message via Skype™ to RDWilson2
Exclamation Beware of flames/embers and dust collectors
Not only saw dust but flour or even just plain dirt-type dust will flash like that and, if it's in a vacuum cleaner/dust collector, it can cause a major explosion.
Ralph D. Wilson II
"Make everything as simple as possible, but not simpler." Albert Einstein.
"Give me six hours to chop down a tree and I will spend the first four sharpening the axe." - Abraham Lincoln
RDWilson2 is offline
post #8 of 12 (permalink) Old 06-11-2018, 12:38 PM
hawkeye10's Avatar
First Name: Don
never knew dirt dust would flash. I learned something today.
papasombre likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 12 (permalink) Old 06-11-2018, 02:42 PM
Knothead47's Avatar
Fine dust will flash like gasoline. Had it happen. I told the wife about this as we have a burn pile in the back of the lot. FWIW, I went to college with a good ol' boy who worked one summer in a feed mill. That is where he learned to chew tobacco. They were not allowed to smoke in or near the mill as the fine dust would flash. If you lived in the country like I did, you would hear of grain mills exploding due to the fine dust igniting.
John T.
Knothead47 is offline
post #10 of 12 (permalink) Old 06-11-2018, 11:54 PM
JFPNCM's Avatar
First Name: Jon
Watch this video to the end to see how bad it can get when a grain bin goes.
Jon
JFPNCM is offline
Single sheet of plywood rocking chair JOAT Project Plans and How To 6 05-05-2018 12:03 PM
Cabinet Plywood Grades Seldonman Tools and Woodworking 4 07-11-2015 10:42 AM
Routing Melamine Hardboard over plywood Foos Starting Off 3 09-17-2012 07:44 AM
Best method to band plywood without tear out Slomoe Router Bits - Types and Usage 8 02-26-2011 10:06 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
