bosch flexi click drill attachment system - Router Forums
 2Likes
  • 1 Post By Stick486
  • 1 Post By Gaffboat
post #1 of 7 (permalink) Old 06-24-2018, 10:31 PM Thread Starter
First Name: Peter
Default bosch flexi click drill attachment system
Hi
may I ask if any one has experience with the above. In particular, how much movement is there in the driving bit in the hex fitting coming out of the drill? Does the bit wobble?
Thanking you in anticipation
Peteroo
Peteroo1 is offline
post #2 of 7 (permalink) Old 06-24-2018, 11:10 PM
You're gonna make me Google it aren't you...
https://toolguyd.com/bosch-18v-flexi...driver-system/
DaninVan is offline
post #3 of 7 (permalink) Old 06-24-2018, 11:22 PM
you needed something to do anyways...
post #4 of 7 (permalink) Old 06-24-2018, 11:30 PM
Default Something Being Done
I AM doing something...see?
DaninVan is offline
post #5 of 7 (permalink) Old 06-25-2018, 06:50 AM
sreilly's Avatar
First Name: Steve
They have to be brothers.........
sreilly is offline
post #6 of 7 (permalink) Old 06-25-2018, 07:52 AM
no...
but thanks for the compliment...
DaninVan likes this.
post #7 of 7 (permalink) Old 06-25-2018, 08:16 AM
Gaffboat's Avatar
First Name: Oliver
I have one and have enjoyed the flexibility of the system. I was drawn to the offset and right angle attachments for tight spaces, and the keyless chuck is an added bonus which allows me to use up to 1/4” standard drill bits, giving me a more extensive range of sizes than the hex bits I own.
I used a Bosch PS20 cordless driver for years, but the new Bosch Flexiclick is now my go-to tool. I haven’t noticed any bit wobble with the system, but I only use it for pilot holes and small projects where the drill press either can’t be used or would be overkill. It is the cordless screwdriver I use most often.
The various attachments are easy to change and lock securely in place. You have the option of locking the offset and right angle attachments in 16 different positions. You can even use hex bits with none of the attachments in place.
Gaffboat is offline
Vacuum System Almost Finished MEBCWD Show N' Tell 5 02-09-2012 09:17 AM
Sold: New Delta 17-935 mortising attachment anniekirk Woodworking Classifieds 2 04-18-2011 06:49 AM
No Lift Systems To Fit Bosch 1619EVS 3.25HP Router? DennisP General Routing 4 01-20-2010 05:23 PM
Outlook Express problems BrianS Lobby 6 01-06-2008 07:23 AM
