bosch 12v flexi click LOCKING BIT HOLDER - Router Forums
post #1 of 2 (permalink) Old 07-17-2018, 08:29 PM Thread Starter
First Name: Peter
Default bosch 12v flexi click LOCKING BIT HOLDER
Hi
may I ask if the "locking bit holder" which is what Bosch calls the quick chuck assembly on the above drill, allows the driving bit to go into the armature fitting on the above drill? Does the bit wobble at all like on most drill drivers?
thanking you in anticipation
Peteroo
Peteroo1 is offline
post #2 of 2 (permalink) Old 07-20-2018, 07:57 AM
Gaffboat's Avatar
First Name: Oliver
The bit does not go all the way into the motor's hex drive when using the locking bit holder, however the driver can be used without any of the accessory holders. Regardless of which method you choose, there is still the inherent wobble encountered with most drill drivers. The wobble isn't a problem for me because I don't use the tool when I need precision drilling. I have found the offset, right angle, and keyless chuck attachments to be very useful.
Gaffboat is offline
Bosch 12v flexi click Peteroo1 Tools and Woodworking 2 07-16-2018 11:13 PM
Bosch 12v Flexi Click drill driver Peteroo1 Tools and Woodworking 1 07-09-2018 07:46 AM
bosch flexi click drill attachment system Peteroo1 Tools and Woodworking 6 06-25-2018 08:16 AM
New Here Ship4Brains New Member Introductions 26 01-03-2018 05:43 PM
Xmas - I got a Triton TRA001....now what table? mikeyo76 New Member Introductions 10 12-26-2017 04:13 PM
