Tablesaw problems again - Router Forums
 30Likes
post #1 of 31 (permalink) Old 07-21-2018, 10:58 PM Thread Starter
Default Tablesaw problems again
My patch job on my Craftsman 113.298762 let loose. The pulleys started slipping again (maybe a little more than started) on both the motor and arbor. I've heard that machined pulleys are better than the stamped ones. Seems the screws and keys keep letting loose on me.
I like this saw, plus it's a bear to move out of the basement. Should I try it again or bite the bullet and go for a new one?
Is In Line Industries the place to go for these parts, or are there others??
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #2 of 31 (permalink) Old 07-21-2018, 11:16 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
if its just the grub screws loosening, use some blue loctite on the thread and tighten a little bit harder.
Roy Drake likes this.
sunnybob is online now
post #3 of 31 (permalink) Old 07-21-2018, 11:51 PM
install one screw on top of the other as lockdown......
post #4 of 31 (permalink) Old 07-22-2018, 12:29 AM
If the motor has a lot of starting torque then that might be the problem. If the arbor doesn't have a keyway and the pulleys are gripping with only grub screws then I would drill a shallow hole where the grub screw goes on the shaft. Browning sheaves are much better than the cast potmetal ones and aren't that expensive in the sizes you need and single groove. https://motorsandcontrol.com/brands/...lleys-sheaves/
Danman1957 and artman60 like this.
post #5 of 31 (permalink) Old 07-22-2018, 01:30 AM
good choice of sheaves...
post #6 of 31 (permalink) Old 07-22-2018, 07:30 AM
My friend has a woodmizer saw mill. same problem. pulley would move on shaft. tried liquid materials on set screw. did not stop problem. Then I added silcon to both sides of key in grove. no movement since then. let it dry for at least a day
artman60 likes this.
mulberry is offline
post #7 of 31 (permalink) Old 07-22-2018, 08:55 AM Thread Starter
what is silcon?
Just looking at the In-Line site. According to them the motor has a 2 1/2" pulley and the arbor is a 2 1/4". The ones that failed were both 2 1/2". Does that make a difference?
HJ
Detroit Burbs
post #8 of 31 (permalink) Old 07-22-2018, 09:09 AM
First Name: Gary
Graingers has the good pulleys, Also don't use plated keys. If your pulley doesn't have a keyway...File a flat on the shaft for the set screw to set against. Using double set screws can lead to more problems than it solves.
gmercer_48083 is offline
post #9 of 31 (permalink) Old 07-22-2018, 09:35 AM
Lots of cures suggested to try. If they don't work, get a new, better saw. I can imagne how frustrating an unreliable tool can be. Of course, what you get will depend a lot on your budget.
mgmine and artman60 like this.
post #10 of 31 (permalink) Old 07-22-2018, 10:14 AM Thread Starter
It's not so much the budget as the weight, Tom. I have to get it down the stairs into the basement.
Think I'll try one more fix. Then, it's time to "explore" alternatives. I got a portable contractor saw as a back up. Still got 25 custom orders to get out and a whole lot of squaring up and gluing to do, since Menards doesn't have any of my blanks in stock.
HJ
Detroit Burbs
some items don't want to work. Stick486 Site Help and Suggestions 301 09-29-2017 08:28 AM
Problems, Problems, Problems..... Frankj3 Sign Making 9 07-04-2016 09:21 PM
Tablesaw with teflon coating lennyk Tools and Woodworking 16 02-11-2014 01:12 AM
Problems, problems, problems nikki1492 General Routing 7 07-21-2009 08:50 AM
