Looking for a part - Router Forums
 1Likes
post #1 of 11 (permalink) Old 07-22-2018, 11:22 PM Thread Starter
Default Looking for a part
Hey folks
I picked up an older router and while cleaning it up I broke the control cable but sears say the cable is discontinued. It is a craftsman router model 315.17380 control cable or part 65 in the manual. Does anybody know where I can find a replacement or a modification I can make?
Jeremy Andersen is offline
post #2 of 11 (permalink) Old 07-22-2018, 11:32 PM
Originally Posted by Jeremy Andersen View Post
Hey folks
sad news abounds....
parts for older craftsman tools are very very difficult to come by..
if it's any consolation your router was made Ryobie...
post #3 of 11 (permalink) Old 07-23-2018, 12:50 AM
I looked at the part but I'm still not sure what it does. Can you illuminate that for us?
post #4 of 11 (permalink) Old 07-23-2018, 07:43 AM
First Name: Art
It appears to be some type of movable cable. If so could you modify something like a lawnmower throttle cable or a bicycle cable?
TenGees likes this.
mgmine is offline
post #5 of 11 (permalink) Old 07-23-2018, 08:41 AM Thread Starter
it is a moveable cable. The trigger assembly has a return spring that pushes the cable back up the housing. By the brushes the other end of the cable looks to depress a momentary switch to power on and off.
post #6 of 11 (permalink) Old 07-23-2018, 08:46 AM Thread Starter
Could I just replace the switch with a new external momentary switch? If so what would be a good candidate?
post #7 of 11 (permalink) Old 07-23-2018, 09:37 AM
There are some options. It seems to me I came across a do-it-yourself cable making kit somewhere but I can't remember where. You would cut it length and crimp the connector on the end. The correct ends might still be a problem.
You could also use it with a foot switch. There are both on/off and dead man type switches available. You have to be careful with the on/off type. I have one from Lee Valley and I've found over time that I need to place where I have to reach for it to keep from stepping on it accidentally. If you use a dead man's switch you'll need to bypass the one on the router which shouldn't be that hard.
post #8 of 11 (permalink) Old 07-23-2018, 11:15 AM
TenGees's Avatar
First Name: Paul
Even though that router looks very similar to the 315.17470, the 315.17470 has the switch in the handle and a wire going where your cable goes. If you can't repair the cable, I wonder if there's room for a microswitch in the handle that could be activated by the trigger directly. Then run a wire where your cable was.
TenGees is offline
post #9 of 11 (permalink) Old 07-24-2018, 12:58 PM
Knothead47's Avatar
Try www.ereplacementparts.com as I have found obsolete parts. Now you know why I don't buy Craftsman power tools.
John T.
Knothead47 is offline
post #10 of 11 (permalink) Old 07-24-2018, 04:29 PM
JOAT's Avatar
First Name: Theo
Newest router I have is over 10 years old. I have I think 5, just use one, because it works, and I usually only use one type of bit. I'll keep using it until it dies, toss it, then use one of the others, because they all work. That's my answer to parts availability/non-availability for old routers; get old, working, routers, cheap, and use them as long as you can. For what I do, and how I do it, this works very well for me.
JOAT is online now
Out feed table (Part 3) Coleve Show N' Tell 4 11-21-2017 11:53 AM
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
Craftsman Jointer Part Repcobpg Tools and Woodworking 21 10-01-2012 05:58 AM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
Getting more from my router Tom76 Guide Bushings and Templates 9 01-14-2010 05:31 PM
