Mortise Width? - Router Forums
post #1 of 9 (permalink) Old 04-05-2009, 09:37 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Mortise Width?
How important is the mortise width?
For a 3/4” stock the Trend MT jig manual says that the width of the mortise should be 1/4”
The woodworking for routers book I have says that it should be 3/8”
Not that it’s so important but if you are going to learn might as well get it right
Nicolas
kolias is offline
post #2 of 9 (permalink) Old 04-05-2009, 09:54 AM
Hi Nicolas
To me the bigger the better,, I will some times use a 1/2" one in 3/4" thick stock..
The sheer of a 1/2" teton is way up on the scale it's just a butt joint on steroids
Nicolas
post #3 of 9 (permalink) Old 04-05-2009, 10:08 AM
Ralph Barker's Avatar
First Name: Ralph
Although 1/3 of the width is a reasonable rule of thumb for heavier stock, I think it's sort of dinky for 3/4" thick material. I'd go with 3/8".
The joint test that Fine Woodworking ran recently also showed a significant increase in joint strength for the 3/8" tenon over 1/4".
- Ralph
Ralph Barker is offline
post #4 of 9 (permalink) Old 04-05-2009, 10:18 AM Thread Starter
kolias's Avatar
First Name: Nicolas
So there is no standard, good to know
I will go with 3/8" mortise for this stock
Nicolas
kolias is offline
post #5 of 9 (permalink) Old 04-05-2009, 10:31 AM
First Name: Ralph
The 1/3 rule of thumb or guideline is probably as close to a "standard" as one gets with woodworking. But, I think it's best to consider the nature of the stress a particular joint is likely to encounter, and then design accordingly.
The testing that FWW did was in a machine that exerted force parallel to the face of the boards. That may not be representative of some joints in actual use, however. If, for example, the joint were subject to more of a twisting force, the lateral wall strength of the mortise might be more important.
- Ralph
post #6 of 9 (permalink) Old 04-05-2009, 10:59 AM
Bob and Rick recommend half the material thickness.
post #7 of 9 (permalink) Old 04-05-2009, 12:53 PM
First Name: Chris
I have always used 3/8" on 3/4" wood. I have not had any problems.
chrisrosenb is offline
post #8 of 9 (permalink) Old 04-05-2009, 01:03 PM
Hamlin's Avatar
First Name: Ken
Ummm... actually, you need to consider what it's going to support. Weight makes a difference too. Just so long as you don't go over 1/2 the material thickness, you'll be fine.
Ken
"A VETERAN"
Hamlin is offline
post #9 of 9 (permalink) Old 04-06-2009, 08:27 AM
First Name: Wayne
Nick
I've always used the 1/3 rule and I don't recall ever having a mortise and tenon joint fail. Having said that it only stands to reason 3/8 would be stronger.
Wayne
waynoe is offline
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
Mortise Measuring kolias Tools and Woodworking 15 04-01-2009 06:42 PM
My mortise jig guyos Jigs and Fixtures 5 01-28-2009 08:49 PM
Rounded Mortise & Squared Tenons? Nickbee Table-mounted Routing 15 01-16-2008 08:11 PM
Rolling Mortise Jig - the test simplenik Table-mounted Routing 9 07-23-2007 10:54 AM
