Tool Amp Guidelines - Router Forums
 4Likes
  • 3 Post By Flipsaw
  • 1 Post By Gene Howe
post #1 of 5 (permalink) Old 07-31-2018, 08:49 AM Thread Starter
First Name: JJ
Default Tool Amp Guidelines
Saw this article and just thought I would pass it along . Take care.
https://fwmedia-mkt-prod2-m.adobe-ca...0-wwessentials
Flipsaw is offline
post #2 of 5 (permalink) Old 07-31-2018, 10:17 AM
Thanks JJ. It's a pretty good article and the chart might be handy for someone wanting to wire in a machine. I would disagree with one section though. I can't speak for US code but I think in Canada all the stationary tools must be on their own circuits. The possibility exists that more than one machine could be used at one time which would overload the circuit and wiring. A rough estimate for cost of doing a circuit yourself is only around about maybe $30 per machine which would be about $15 for a breaker, maybe $10 for wire, and $5 for an outlet and that's being generous for wire and box. 220 Volt would be maybe an extra $10-15. The real cost these days is if you have to get a licensed electrician out to do it for you.
post #3 of 5 (permalink) Old 07-31-2018, 04:41 PM
Gene Howe's Avatar
First Name: Gene
Chuck, those codes can be different from one jurisdiction to another, here in the US. Where I am in rural AZ, there's nothing except common sense to prevent wiring several machines to one circuit. The inspector who signed off on my shop wiring job never even asked. And, a couple stationary machine were in place when he did the inspection.
Cherryville Chuck likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 5 (permalink) Old 08-01-2018, 08:54 AM
sreilly's Avatar
First Name: Steve
That would depend on your definition of "stationary". If it is a direct wire, no plug, then yes, it should be on it's own circuit. But the truth is that if you know the max load of a piece of equipment and size both wire and breaker as such you are protected. If another machine is on that same circuit and both run exceeding the amp load then the breaker will trip. If it's borderline then things like starting both at the same time will have an effect as well as you get higher starting amps initially then usually go down to run load amps which is different than rated amps. Common sense says to size breakers and wire to rated amps and seperate the loads. For me, I have a 220V circuit that can run either the Sawstop or the 8" jointer. Both have the appropriate plug and both can be plugged in at anytime as there are 3 outlets in various places in the shop. Only one can run at a time less it trips the breaker which is how it is intended. If this were a multi person shop I'd wire a bit differently but is isn't and won't be as long as I'm here. I also have all outlets numbered according to the breaker number so if you need to work on a circuit, like replacing an outlet, you know which breaker to turn off but take my word on this if nothing else, always check with a voltmeter before continuing. I've had my share of shocking surprises. And if your dealing with 3 phase check all legs to ground. I've had disconnects where the blades didn't all disconnect with the throw of the handle, surprise.
But always check with local and national electrical codes. Inspectors are not responsible for their mistakes. I've seen stuff passed that was totally wrong and dangerous. If you don't know, higher an electrician.
sreilly is offline
post #5 of 5 (permalink) Old 08-01-2018, 08:57 AM
sreilly's Avatar
First Name: Steve
Make that, If you don't know, higher a licensed electrician.
sreilly is offline
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 5 01-18-2020 09:11 AM
Kreg Tool Rip-Cut Saw Guide Frankj3 Lobby 18 10-19-2016 05:05 PM
Results do not match 3d preview edison auto CNC Routing 46 04-02-2016 05:58 AM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
proper tool use locoboy Lobby 0 04-01-2009 02:45 PM
