Table saw projects for beginners - Router Forums
 14Likes
post #1 of 19 (permalink) Old 07-31-2018, 07:40 PM Thread Starter
SaraHandcraft's Avatar
Default Table saw projects for beginners
I am new in this forum and recently I bought my first table saw and I wonder if someone can give me some tips or ideas for a beginners project. I saw this article https://homyden.com/table-saw-projects-beginners/ which describes some good projects and I want to know what do you think about those projects and recommend me others. Would you try anything of those projects? Which one?
A rookie who tries to get better
SaraHandcraft is offline
post #2 of 19 (permalink) Old 07-31-2018, 08:02 PM
hawkeye10's Avatar
First Name: Don
Sara, first let me make you aware of a guy named Ted that sells plans on the net. His plans are not very good, in fact, they are bad. He operates just inside the law so just be aware.
One place for you to look is You-Tube. When they show you how to build something a lot of them sell the plans and some even give them away. Also, there are wood magazines. You can buy plans from them and they do have some free plans. Woodsmith has some plans you might like. You can get them online. Keep us aware of what you are building and ask questions if needed. We really like pictures too.
harrysin likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 19 (permalink) Old 07-31-2018, 08:51 PM
Some of my first proects were tool stands for my other tools. That and a nice bookshelf. I do strongly suggest that you get a Wixey digital angle gauge. You place it on the table, set the zero setting, then place it on the blade and adjust it until ir reads exactly 90. You can't count on the markings on the saw to set an exact angle. It costs about $30 on Amazon. if you make cuts that are not 90, you won't be able to fit pieces together and glue won't stick. I'm attaching an pdf of an article on the 17 things that accellerated my learning to do woodworking. It may save you a bundle in wood and tools over time. One other project you might consider is called a table saw sled. It will make cutting on the saw much safer and it will be something you'll use forever. There are lots of videos on YouTube on how to make a table saw sled.
One last thing, get and use a good mask. Sawdust does terrible things to your lungs. There's more on this in the pdf., and I've included a respirator sold by Rockler Woodworking, which uses four batteries to pull shop air through a filter. I find it makes all the difference for my breathing.
Here's the article, it's long.
post #4 of 19 (permalink) Old 07-31-2018, 09:22 PM
Terry Q's Avatar
First tablesaw projects should be an out-feed table of some sort, a workbench, then shelves and cabinets for storage.
The out-feed table for your tablesaw is a safety item that every tablesaw needs to operate safely. It keeps your wood from falling on the ground after feeding it through the saw, and you from trying to grab it or hold on to it leaning over a spinning blade.
MEBCWD likes this.
Terry Q is offline
post #5 of 19 (permalink) Old 07-31-2018, 09:42 PM
Hi, Sarah(?); perhaps you could fill out your profile...
It's difficult to make suggestions for folks, not knowing their level of experience or what tools they have to work with.
Assuming it's only the TS that you're asking about, and that you have some shop experience, the projects basically breakdown into casework...bookcases, cupboards, etc., hardwood objects like cutting boards, chessboards, small boxes (jewellery, urns, coffee mills, etc) or utility projects like wine racks, tables, furniture (beds, stools, etc.).
My own motivation usually flows from a need for something rather than a random idea, but that's just me.
I think having a need and a budget makes the decision making process somewhat more clear.
Sometimes using common lumber, 1x4 Spruce/Pine/Fir makes way more sense than splurging on Maple or similar.
A LOT of us really dislike working with Medium Density Fibreboard (MDF) mostly because it's brutally dusty to work with, and frankly, not very attractive; but again, to each their own.
The whole Table saw experience is a huge topic and a long learning curve. The primary focus at this point is to learn what's safe and what isn't!
There are a lot of great You Tube vids BUT there are also some really dangerous suggestions; the trick is to spot the bad ones, before you get hurt.
If you're just getting started, please use your bladeguard and anti kickback pawls whenever possible.
Also make yourself some basic pushsticks.
I'll try and get a moment to take a picture of my handsaw handle style pushstick; it both pushes and stops your material from rising up.
Please, please, please take TS safety SERIOUSLY!
TWheels likes this.
DaninVan is offline
post #6 of 19 (permalink) Old 07-31-2018, 09:51 PM
Push sticks...
Woodworking Template: Table Saw Push Sticks | Kurt's Blog
https://www.google.com/search?q=Tabl...w=1920&bih=923
The first link is the style I use and I'll never go back to commercial ones.
TWheels likes this.
DaninVan is offline
post #7 of 19 (permalink) Old 08-01-2018, 01:05 AM
JOAT's Avatar
First Name: Theo
Originally Posted by DaninVan View Post
Push sticks...
Totally agree with push sticks. Make them, and USE them. If you are like me, you will need to keep making them. I use one, next time I need it, can't find it, so it's make another. They do not need to be fancy, just to work properly. I make mine out of leftover pieces, and don't hold to any measurements or such, just a general shape. I would not use really nice wood for them, they tend to get chewed up by the sawblade and after a bit are useless. I use mostly 1/2" plywood, because that is what I mostly use. I cut mine out with my scrollsaw, or bandsaw.
DaninVan likes this.
JOAT is offline
post #8 of 19 (permalink) Old 08-01-2018, 07:12 AM
First Name: mary
Welcome to the forum
marecat3 is offline
post #9 of 19 (permalink) Old 08-01-2018, 09:00 AM
sreilly's Avatar
First Name: Steve
Welcome Sara.
sreilly is offline
post #10 of 19 (permalink) Old 08-01-2018, 12:05 PM
JFPNCM's Avatar
First Name: Jon
Welcome aboard Sara. The points raised above are all well made and we look forward to your posts.
Might one inquire as to which TS you will be using? Selecting a blade for the project based on the cuts to be made and type of wood is another critical point.
Herb Stoops likes this.
Jon
JFPNCM is offline
Another Newby Tweety New Member Introductions 13 12-18-2017 06:38 AM
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
