Machine Jointing Sequence? - Router Forums
 1Likes
post #1 of 16 (permalink) Old 08-12-2018, 04:05 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Machine Jointing Sequence?
Jointed a board and it became wedge shaped,why?
Sequence? If I start with a bowed board and give it several passes until the face is flat, then edge. If the edge is not square with face, do I then edge, then face, then edge, face until all square. Or continue edging until the edge is square with the face. Then run through the planer?
Gaia is offline
post #2 of 16 (permalink) Old 08-12-2018, 04:20 PM
face then edge...
cheat on the edge..
post #3 of 16 (permalink) Old 08-12-2018, 05:57 PM
You register the edge to the face so face comes first. Jointers are good at making wedges. Planers make them flat again.
post #4 of 16 (permalink) Old 08-12-2018, 07:07 PM
Scap's Avatar
First Name: Scap
Saw a video today that discussed this. Think it was woodworkers guild...
Apparently, the jointer isn't perfectly 90* to the fence.
The work around is to joint one edge to one face of the board, then when you joint the opposite edge use the other board face. That way the two opposing angles match to make a flat glue up.
Scap is offline
post #5 of 16 (permalink) Old 08-12-2018, 07:15 PM
parallel the opposite side on the TS...
post #6 of 16 (permalink) Old 08-12-2018, 09:21 PM
If the board had any twist to it at all then it needs to go through a planer after flattening one side in order to get both faces parallel to each other. Since the opposite face may not be co-planar until it does go though the planer then if you joint the edges before hand you should register the same face against the jointer fence. And that's after you made sure that both edges are co-planar by ripping one edge on the TS after the first edge gets jointed like Stick said. My jointer sits right behind me at the TS and I often have both running at the same time for that reason.
post #7 of 16 (permalink) Old 08-13-2018, 07:13 AM
sreilly's Avatar
First Name: Steve
All above is good advice but I would first check and make sure my knives are adjusted properly. Then check that the tables are parallel. If the jointer is setup properly then proceed. I had bought a used jointer some time back and found that my first board was a wedge no matter what. Had I taken the time to check the tool I would have found it was out of adjustment. The knives were OK but I replaced them and had them sharpened as well. Due diligence will help with success. Of course knowledge doesn't hurt either......
-Steve
sreilly is offline
post #8 of 16 (permalink) Old 08-13-2018, 04:11 PM
Contributor of the Month
First Name: thomas
O.k. Chuck, now say it again in English, eh.
thomas1389 is offline
post #9 of 16 (permalink) Old 08-13-2018, 05:17 PM
Re the "flattening one side" part.
You can do that with the planer as well. You'd have to set it up on an already flat board, so that one face is rock steady on shims, against the flat carrier board. Basically a shim sandwich.
Once the top face is evenly flat, remove it from the carrier, flip it over and do the opposite face. Now the two faces are 'co-planar'...ie parallel to each other and dead flat on both faces.
DaninVan is offline
post #10 of 16 (permalink) Old 08-14-2018, 01:49 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks everyone.
Gaia is offline
Machine Jointing Correct Method Gaia Tools and Woodworking 12 07-27-2018 09:36 AM
What makes a good CNC router? Gundawg CNC Routing 19 11-13-2017 02:18 PM
For Sale: Weeke BP100 for sale in Salt Lake City sarahfitz0213 Woodworking Classifieds 3 07-10-2017 10:06 AM
My new improved homemade router milling machine. Mark55 Table-mounted Routing 16 02-01-2013 05:42 PM
