Router Guide Bushing Question - Router Forums
post #1 of 4 (permalink) Old 10-30-2018, 07:00 AM Thread Starter
Contributor of the Month
Default Router Guide Bushing Question
I need to make a mortise 3/4" wide by 3/4" deep on 4 ends of a frame. Frame is already assembled so mortising options are limited. I made a mortising jig from 3/4" ply and needed a 1" slot to accept a 1" guide bushing which will accept a 3/4" router bit. I don't have a 1" diameter router bit so I made a 3/4" slot on the router table and then was going to use a rabbeting bit and flush trim bit to widen the slot to 1". But my 1" slot turned out a tad wide. I suppose I could just run the bushing against one side of the jig slot? I put some tape around the bushing to get a tighter fit but not sure if something might go wrong and mess up the mortise.
Any thoughts or suggestions or just redo the jig?
JIMMIEM is offline
post #2 of 4 (permalink) Old 10-30-2018, 09:55 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
A few photographs will bring forth more suggestions Jim.
Harry
harrysin is offline
post #3 of 4 (permalink) Old 10-30-2018, 06:04 PM
Are you talking a square or round mortise? if round, use a drill press and Forstner bit. If square, then I'm not quite sure what you're talking about. My guess is that you could use the Forstner to clear most of it and then carefully chisel it square. If you're not comfortable using a chisel, do a trial run on some scrap of the same material. Sharpen your chisels before you start--razor sharp. This may not work well if the corners have complex beads and coves. Picture please.
DesertRatTom is online now
post #4 of 4 (permalink) Old 10-30-2018, 09:15 PM
TWheels's Avatar
While I agree with @harrysin that a photograph or drawing would be very helpful, a 1 inch PC type guide bushing is available from Lee Valley. I am not aware of any other source for the 1 inch; sets are available but none
that I have seen have the 1 inch. 1-3/16" Brass Template Guides - Lee Valley Tools
Lee Valley is also the sole source for the Oak Park style guide bushings. 1-3/4" Brass Template Guides - Lee Valley Tools
Lee Valley is doing fee shipping on orders over $40
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
brass router bushing guide kit set petermac67 Guide Bushings and Templates 6 10-24-2011 08:43 PM
brass router bushing guide kit set petermac67 Guide Bushings and Templates 3 10-16-2011 07:14 AM
rockler guide bushing size question blurry Router Bits - Types and Usage 5 01-30-2009 12:20 PM
