half-lap joint question - Router Forums
 12Likes
  • 1 Post By woodpig
  • 3 Post By Stick486
  • 1 Post By DaninVan
  • 6 Post By Stick486
  • 1 Post By Oakwerks
post #1 of 10 (permalink) Old 10-31-2018, 10:22 AM Thread Starter
First Name: Bryon
Default half-lap joint question
Half-lap joints typically feature one board "lapping" over another, as you know. My question is this: does the board on top--the one that "laps over" the one on bottom--necessarily have to "lap over" the full width of the bottom board? That is, would there be a significant disadvantage if the top board only "lapped over" part of the width of the bottom board, so that its end grain didn't show through on the finished joint?
I've attached a screenshot of a simple drawing that I did on Microsoft Publisher (I don't know how to use SketchUp yet). The image at the top shows a traditional half-lap joint, with the top board lapping over the full width of the bottom board. The image below that shows the theoretical joint that I'm asking about, with the top board only lapping over part of the width of the bottom board.
Hopefully this makes some kind of sense.
Name:	lap joints.JPG
woodpig is offline
post #2 of 10 (permalink) Old 10-31-2018, 11:04 AM Thread Starter
First Name: Bryon
Here's another drawing that might better illustrate what I'm talking about. First image is the conventional half-lap joint; second image is the partial half-lap that I'm asking about.
Name:	conventional half-lap.JPG
Name:	partial half-lap.JPG
Herb Stoops likes this.
woodpig is offline
post #3 of 10 (permalink) Old 10-31-2018, 11:23 AM
The glued joint will be stronger than the rest of the piece. The width of the workpiece will matter somewhat. I think you just want to only have endgrain showing on one edge of the joint, not both. Personally, I think the L shaped endgrain is not as attractive as a conventional lap. But if the piece is wide enough you could turn the overlapping piece into a tennon so the entire end is endgrain. Cut a mortise to fit the tennon. The glue will help reinforce and hold the end piece in place.
post #4 of 10 (permalink) Old 10-31-2018, 11:25 AM
no...
not at all...
TwoSkies57, MEBCWD and Herb Stoops like this.
post #5 of 10 (permalink) Old 10-31-2018, 03:24 PM
Following on from the other comments, consider a Bridle Joint...
(a bridal joint is a whole 'nuther topic!)
Woodwork - Bridle Joint information and Pictures
jj777746 likes this.
DaninVan is offline
post #6 of 10 (permalink) Old 10-31-2018, 05:28 PM
woodpig is trying to loose as much end grain as he can...
a better plan ''B'' would be a mitered lap joint (drawing)
BTW... the real deal bridle... (2x photos)
you are showing a lapped corner joint
post #7 of 10 (permalink) Old 11-01-2018, 06:46 AM
that is also known as an open M&T...
post #8 of 10 (permalink) Old 11-01-2018, 07:40 AM
First Name: Ray
The best joints, regardless of design, are those that maximize the glue surface area, face-to-face. Glued end grain-to-end grain does not provide the same strength as face-to-face surfaces.
It's as simple as that.
rayk2 is offline
post #9 of 10 (permalink) Old 11-01-2018, 07:50 AM
First Name: Kurt
Maybe I’m missing something, but how would cut the partial half lap ??
The piece on the bottom ....
TenGees likes this.
Oakwerks is offline
post #10 of 10 (permalink) Old 11-01-2018, 08:42 PM
Another option would be cutting mitered ends and putting in a hidden spline, similar to cutting and gluing in a biscuit.. Or use dowels. Or double biscuits if you have the space. All of which will make a no-endgrain joint. Or, lightly glue up the miter corners, then cut a spline across the corners and use a matching or contrasting spline on the outside. Kind of depends on what part of the corner you want to be endgrain (or spline) free, the inside corner or the outside.
Maloof Inspired rocking chair build TwoSkies57 Project Plans and How To 281 06-16-2015 04:02 PM
Half Lap joints ptofimpact Router Bits - Types and Usage 15 02-18-2013 03:44 PM
half lap help drbbob Project Plans and How To 4 06-23-2011 02:51 AM
need half lap joint jig DJeansonne Jigs and Fixtures 11 08-17-2009 09:27 PM
