Craftsman 3 Wheel Band Saw Rehab - Page 2 - Router Forums
 15Likes
post #11 of 17 (permalink) Old 11-14-2018, 12:19 PM
Those blades have to be pretty long. Really nice rehab job. Looks good as new.
post #12 of 17 (permalink) Old 11-14-2018, 12:22 PM Thread Starter
First Name: Doug
Originally Posted by DaninVan View Post
Wow! Looks better'n new!!
Thanks !
I hadn't seen those 3 wheel jobs around for awhile; kind of wondered what had happened to them.
Yeah I believe they were popular back in the 1970's
But I have read that blade fatigue is a common problem with them, Especially with wider blades!
dwall174 is offline
post #13 of 17 (permalink) Old 11-14-2018, 12:29 PM Thread Starter
First Name: Doug
Thanks !
62" Pretty good for a bench top saw!
dwall174 is offline
post #14 of 17 (permalink) Old 12-29-2019, 12:58 AM
Red face Craftsman 1957 3 wheel band saw
Mom bought Dad a Craftsman 3 wheel band saw (Seally) for Christmas in 1957. Dad use to cuss at the saw every time he used it, as it would break blades. Both parents are gone now, but I wanted the saw for the memories. The problem with the saw was due to low tension on the blade, and when you fed wood in, the blade would rotate and catch a tooth on the table top, and Bam!, the blade would break. You could tighten the tension knob until the tensioner rod bottom out inside the knob, and blade was almost tight but you could tell something was not right yet. Doing a search on the internet I did find the owner manual from 1957. Wow! Looking at the tensioner details there was a cylindrical spacer between the Knob and saw that causes the adjusting knob to sit further out, giving the assembly more travel. So when dad changed the blade at one point the spacer fell off and he probably did not notice it. ( fell to floor or something). I made a space about 1/2 inch in length, with hole the size of the tensioner threaded rod. I am now able to tension the blade to get a Guitar 'G' note when you pluck the blade. The saw works great.
A 3 wheel band saw has a thinner blade. Using a 2 wheel blade that is thicker and bent over a smaller diameter wheel cause the 2 wheel weld to break. Welding on a 3 wheel blade uses a different process to get the strength at the weld with thinner metal. Cheap 3 wheel blades are welded the same as a 2 wheel blade and will break. You must get a 3 wheel blade that has the quality 3 wheel weld or the blades will always cause you headaches. My 1957 Craftsman band saw is running great, cuts straight, and wished Dad were here to see what all the cussing was about!
DaninVan and DesertRatTom like this.
MrMike72 is offline
post #15 of 17 (permalink) Old 12-29-2019, 02:14 PM
Welcome, Mr. Mike. Great info. If you have the time, perhaps you could check out the tool manual archive and add yours if it's not already there?
DaninVan is offline
post #16 of 17 (permalink) Old 12-30-2019, 12:18 PM
TenGees's Avatar
First Name: Paul
Originally Posted by MrMike72 View Post
...Welding on a 3 wheel blade uses a different process to get the strength at the weld with thinner metal...
The one that we had at a sign shop that I worked at, had a built in welder. It just butt joined (with adjustable spring tension in the jaws) and an electric arc. The wheels weren't all that small on that saw though because it was pretty big.
TenGees is offline
post #17 of 17 (permalink) Old 01-01-2020, 12:04 PM
Nickp's Avatar
First Name: Nick
Welcome, Mike...great work on the rebuild...must have taken a while.
Nick
Nickp is online now
Craftsman Jointer Rehab dwall174 Tools and Woodworking 9 01-15-2019 04:42 PM
Games Wheel - Wheel of Fortune style. darsev Show N' Tell 10 03-13-2015 07:01 PM
Very rusty collet and nut in Craftsman. Possible rehab? Goblu General Routing 8 05-09-2014 07:53 PM
Bench grinder -- difference in 6" & 8" wheel heating object to be ground corbind Tools and Woodworking 13 05-12-2012 06:57 PM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 10:51 PM
