I've added some shop tools - Router Forums
 13Likes
post #1 of 15 (permalink) Old 11-20-2018, 02:43 AM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default I've added some shop tools
I'm on and off a lot here, and my times away get longer and longer. In the interim I've been adding some tools that I need to get up and running! This past summer I bought a Seco 24" wide belt sander, it's a 3phase unit. And then just recently here purchased a Robland E300, also a 3 phase. Between those two, I bought a 20hp 3ph converter, but... Nothing is hooked up yet and it's winter here. Winter in my shop is almost like winter outside my shop, with just a little less snow, but there is snow. I'm looking for a new shop! I've mentioned the weather issue before and I've been looking for several years but so far I'm still in the same barn. I can't add attachments at this time, I'll see if that's up tomorrow.
kp91, MEBCWD and Herb Stoops like this.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 15 (permalink) Old 11-20-2018, 08:04 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
It's always good to see you post Jack and I hope all is going well with you. Those machines tell me that you're still in business.
Jack Wilson likes this.
Harry
harrysin is offline
post #3 of 15 (permalink) Old 11-20-2018, 08:58 AM
Danman1957's Avatar
Jack.
I am fortunate to use a garage that is attached to my home as a shop. I have seen some shops created from used shipping containers. They are weather resistant and in the USA are quite affordable. If I didn't have the garage, I would more than likely try one or more of these units. Some are even insulated. Just add a door and a couple of windows and some power, and maybe a source for some heat.
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #4 of 15 (permalink) Old 11-20-2018, 10:24 AM
My 12x24 shed-shop was hauled in via a large trailer more than a decade ago. If I had it to do over, I'd have gotten the 16x24 size. It is a pretty basic structure and sits on a crushed rock base. Insulated with AC and heat that takes about an hour to warm up. A skirt of redwood pickets sealed off the under floor, although I wish I'd also added some insulation under it. If I'd had the larger size built, I'd have used 2x6 studs to add R38 insulation, and had a concrete pad poured. I would also have had double glazed windows installed instead of single. I put foam insulation over the cheap windows because they were such a heat leak.
My wife had an electrician install an electrical subpanel, which now feeds whichever shed I'm in. The DC unit. Moving that outside really opened space inside--much more comfortable, cleaner and open.
I'm posting this because I sense a new shop is in your future. You won't believe how nice it is to walk into a warm and conveniently large shop. I guess you are in a commercial woodworking business from the comments. A decent workspace is a basic human right, to my thinking. Hiring someone to help you build it is a possibility, it's financing it that's the challenge for most of us. But the warm, comfy shop has outlasted the bill for it by a long shot, and if it's up to code, it adds value to your property should you move later.
post #5 of 15 (permalink) Old 11-20-2018, 11:18 AM Thread Starter
First Name: Jack
Originally Posted by Danman1957 View Post
Jack.
Dan
Maybe that's something to consider, but I have a pretty good size shop, 32'x44'. And we don't have much room on OUR property, so I rent space across the street.
Danman1957 and DesertRatTom like this.
Jack
post #6 of 15 (permalink) Old 11-20-2018, 11:33 AM Thread Starter
First Name: Jack
Harry, always an honor to have you comment on one of my posts! Yes, I'm still in business and moving forward to a time when I do shop work exclusively and no more crazy customers with their Taj Mahal expectations. Or grungy disgusting work, or working outside in 0 (Fahrenheit) weather.....
harrysin likes this.
Jack
post #7 of 15 (permalink) Old 11-20-2018, 12:23 PM
I insulated mine and use a radiant tube heater and it allows me to work fairly comfortably even at a fairly low setting. If I have to glue or finish I turn it up for a while.
Danman1957 likes this.
post #8 of 15 (permalink) Old 11-20-2018, 03:00 PM Thread Starter
First Name: Jack
No more editing posts? I have misspelled words and it drives me nuts!
Jack
post #9 of 15 (permalink) Old 11-20-2018, 06:41 PM
Have instead of gave? If that's it I changed it.
post #10 of 15 (permalink) Old 11-20-2018, 06:49 PM
hawkeye10's Avatar
First Name: Don
Jack, you need to get this. I am really bad at spelling and this helps me from being so dumb. It's also free.
https://www.grammarly.com/
Don in Murfreesboro,Tn.
hawkeye10 is offline
Checking In Knot Norm New Member Introductions 21 08-22-2018 09:27 PM
First box joints Debbie Show N' Tell 39 04-10-2018 06:35 PM
Getting started martyb New Member Introductions 9 10-07-2017 03:38 PM
New member from Upper Michigan chiefifd32 New Member Introductions 23 05-24-2016 08:11 AM
Hello bialy100k New Member Introductions 9 05-23-2016 09:31 PM
