Incra I Box problems. - Router Forums
 3Likes
post #1 of 11 (permalink) Old 11-21-2018, 11:58 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Incra I Box problems.
I am making a "Breakfast Tray" and the sides are splayed 15*. I want to use box joints and I am having trouble getting them to fit. The guy that has the plans on Amazon and you can watch a video free if you have Prime. If I can I will put a link below. Joining the rail start in the video at 19:55 minutes. There is one back and two side rails that are splayed 15* out on the bottom plus cut at 15* on one end on the sides and for the back, it's cut at 15* on both ends. Here are some pictures. These are test cuts and I know the back is too tall and will have to be cut to size. I have tried to give all the information you might need but it seems I don' give enough so ask away and I will try to answer them. Thanks
Well, I can't get but one picture uploaded. It must be the computer because I know it's not me.
https://www.amazon.com/Woodcademy/dp...e=UTF8#nav-top
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 11 (permalink) Old 11-21-2018, 12:05 PM
do the heels of the sockets have a 15 degree kant...
post #3 of 11 (permalink) Old 11-21-2018, 01:19 PM Thread Starter
hawkeye10's Avatar
First Name: Don
No Stick, they don't. Looking at the video again I think he was having the same problem and he just let it go. I don't see any way of doing at an angle in the sockets.
post #4 of 11 (permalink) Old 11-21-2018, 01:57 PM
JOAT's Avatar
First Name: Theo
I don't do fancy work like that. But, if I were going to want something with splayed sides and joints, I think I'd start with a oversize squared piece, cut the joints, then angle cut the piece, splaying it that way. Never tried it, but off-hand can't think of any reason it wouldn't work. At least that's the way I'd try it.
Hmm, I can't figure if that would leave little square holes or not. But even if it did I think I'd still go with it, and fill the holes with black epoxy or something. Then if anyone asked I'd just tell them that was part of the design, and intentional.
Even better. This should answer your questions. Just choose your weapon. https://www.google.com/search?ei=Rrn...99.tgcp-pfoFMs
I love google.
JOAT is offline
post #5 of 11 (permalink) Old 11-21-2018, 05:54 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Thanks, Theo. This video shows the correct way it needs to be done. I just don't think I want to try and make a jig like that for this one project. I may just butt joint the ends and put a couple of small dowels for strength. What do you think about that?
Herb Stoops likes this.
post #6 of 11 (permalink) Old 11-21-2018, 07:43 PM
That is what I would,and have done in the same situation/ or miter it an a compound miter joint.
Herb Stoops is offline
post #7 of 11 (permalink) Old 11-21-2018, 08:56 PM
use a wedge to angle the board in the jig..
straight cut the sockets per say and over cut the tail length a fuzz...
assemble...
trim the tails to fit...
post #8 of 11 (permalink) Old 11-21-2018, 09:42 PM
JOAT's Avatar
First Name: Theo
I like it. K.I.S.S. triumphs again.
JOAT is offline
post #9 of 11 (permalink) Old 11-22-2018, 10:10 AM
CharleyL's Avatar
First Name: Charley
@Stick486 has the way.
I haven't tried this with the I-Box jig, at least not yet, but you should be able to make a wedge and attach it to the sacrificial strip in the I-Box jig, to keep your work held at the correct angle during the cutting process. I have made a bunch of spare sacrificial strips for my I-Box jig and would not hesitate to modify one of them for this purpose. I used the original sacrificial strip as a template and cut about 16 more from a 2' X 4' piece of 1/4" MDF that I purchased at Home Depot for about $5. About an hour later I had made enough for my I-Box jig to likely last me the rest of my lifetime.
My "Kyrmi Original Mini Fence" jig (another form of box joint jig) came with wedge shaped fence pieces to use with the miter gauge on the table saw to allow doing this when making 5, 6, and 8 sided boxes. There isn't one ready made in the set for a 15 deg angle, but it should be possible to do this when using that jig as well.
An I-Box jig should also be capable of this if the needed wedge is made for it. You could either trim the work at the angle before cutting the box joints, or just cut the box pins longer than needed and trim the excess off after assembly. A little extra pin length on box joints, trimmed off after gluing and assembly, always produces the best result.
Please post photos of your attempt and success.
Charley
Central North Carolina
CharleyL is offline
post #10 of 11 (permalink) Old 11-22-2018, 04:08 PM
Gaffboat's Avatar
First Name: Oliver
Default Use an angled backer
I made a simple angled backer for my shop-built box joint jig that worked well for making joints on an angle. The angle has to match what it needed for the angle of the sides, and you can see how well the joint look when assembled.
Name:	1 Box Joint angled backer.jpg
Name:	2 Cutting the angle.jpg
Name:	3 Finished joint.jpg
Name:	4 Close up.jpg
Name:	5 Shop built box joint jig.jpeg
TwoSkies57 and Stick486 like this.
Gaffboat is offline
cut off bin to box to planter to--? JFPNCM Show N' Tell 12 08-27-2019 12:30 AM
Finishing kywoodchopper General Routing 13 01-15-2018 01:05 PM
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
My first box joints with the Incra Ultralite p3auul Jigs and Fixtures 13 01-19-2013 02:41 PM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
