anyone replaced the chuck on a drill press? - Page 2 - Router Forums
 45Likes
post #11 of 30 (permalink) Old 11-22-2018, 01:41 AM
Originally Posted by Herb Stoops View Post
There is nothing more frustrating than having a keyless chuck slip on the cordless drills. Or tohave it loosen when the drill is reversed. The only down side to keyed chucks is loosing or misplacing the key, unless there is a spot on the motor to hold the key when not in use.
Retractable key chain...
rwl7532, TenGees and Nickp like this.
post #12 of 30 (permalink) Old 11-22-2018, 06:53 AM
TenGees's Avatar
First Name: Paul
I took the keyless chucks off of some old battery drills that the replacement batteries were unavailable or as expensive as a new drill. I put the chucks on a few corded drills and haven't had a problem but I did keep the old chucks just in case. I still have keyed chucks on two (heavier) corded drills and my little drill press.
I think some people have an issue with some keyless chucks because they don't work the same as older ones. My newer Bosch cordless has a chuck that instead of just spinning it in your hand to tighten, it requires an extra twist without the motor running... it kinda clicks and then it's tight. Takes some getting used to but works.
All that being said, I'd still recommend a keyed chuck on a hammer drill, drill press or any drill that you often use large bits.
TenGees is offline
post #13 of 30 (permalink) Old 11-22-2018, 09:10 AM
Knothead47's Avatar
I "mounted" the key on my Crapsman corded drill with black tape. For the DP, I tied a heavy cord to the key and hang it on a magnetic hook from HF that sits in the side of the DP.
JFPNCM, TenGees, Nickp and 2 others like this.
John T.
Knothead47 is offline
post #14 of 30 (permalink) Old 11-22-2018, 09:15 AM
Gaffboat's Avatar
First Name: Oliver
I replaced the chuck on my drill press several years ago with a new keyed chuck. I use one of the those magnetic pencil/cord keepers from Rockwell to keep the key handy on the drill press. The key is easily used with the magnetic holder attached.
JFPNCM, TenGees, Stick486 and 1 others like this.
Gaffboat is offline
post #15 of 30 (permalink) Old 11-22-2018, 09:22 AM
difalkner's Avatar
First Name: David
I attached mine with a small chain about 30 years ago and it's still working just fine. It's always handy and all I have to do is reach for the chain hanging from the motor mount. Nothing to wear out, always attached, always convenient, never in the way - works for me!
David
Herb Stoops likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #16 of 30 (permalink) Old 11-22-2018, 12:28 PM
I epoxied a rare earth magnet to the side of my press to hold the key on. After quite a few years the epoxy let go. Then I found out that the magnet either sticks to the chuck key or the side of the drill press when I use the key. It makes no difference which way. If it sticks to the key I can put it back anywhere on the DP. If it sticks to the press then I have to stick the key back to the magnet.
post #17 of 30 (permalink) Old 11-22-2018, 02:14 PM
and if the key is spring ejection equipped..
all the more gooder...
mjadams61 likes this.
post #18 of 30 (permalink) Old 11-22-2018, 05:15 PM
mjadams61's Avatar
First Name: Marlin
I have a ryobi 18v 2 speed with a keyless chuck and since my stroke a few years ago I have not been able to really tighten it so I am going to get a key chuck for it.
mjadams61 is offline
post #19 of 30 (permalink) Old 11-22-2018, 08:07 PM
First Name: Doug
Originally Posted by twmv86 View Post
I have an old delta radial drill press and have thought of replacing it with a keyless chuck
i liked it being a radial and back then that overshadowed it not having a crank to raise and lower the table.
Old Delta radial drill press & not having a crank to raise & lower the table!
I'm guessing it's a 11-280 drill press?
If so I believe those used a Jacobs 33 taper chuck!
Just in-case you didn't know about this fact, They also have a really easy way to remove spindle/chuck assembly.
dwall174 is offline
post #20 of 30 (permalink) Old 11-22-2018, 08:27 PM Thread Starter
First Name: n/a
mine is a 11-090. I saw a video removing a chuck but it wasn't my model. t will have to hunt around for the best chuck for the $.
twmv86 is offline
Drill for vintage Craftsman 335.25926 drill press bclarknc Tools and Woodworking 12 04-13-2014 06:49 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill Press Dust Control Gaffboat Jigs and Fixtures 19 07-26-2012 02:29 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
