Toys, Toys, and more toys - Router Forums
post #1 of 5 (permalink) Old 11-23-2018, 05:56 PM Thread Starter
sreilly's Avatar
First Name: Steve
Default Toys, Toys, and more toys
My head is spinning after having watched several videos covering reviews on both the PanoRouter and The Router Boss. Let me preface this post with the fact that I have both a new Leigh Super FMT for making mortise and tenon joints and a new Porter Cable 4012 Dovetail jig for through and half dovetails. Buttttt, looking at the PanoRouter the possibilities seem far greater if not a bit more confusing at first like any new machine. And then there's the Router Boss which can do most all of the same plus raised panels. Of course you can just buy them all, end up in the poor house, probably divorced, and alone with your tools living in a remote shed somewhere. Ok maybe a bit dramatic but I wouldn't bet the house on that. Is there anyone here familiar with both the PanoRouter and the Router Boss to give some sage advice on the limitations between the two? I have to admit from what I've seen on-line about the Router Boss it seems like a great machine but seldom do I hear/see reviews after someone has had and used it for an extended period of time. Either machine is an investment so I'd really prefer to see one in person but that's very unlikely at this point. As neither has a Black Friday special it's not a pressing matter but one I'm very interested in pursuing. I bought the Leigh Super FMT on an impulse due to it's being dropped from production and the great sale price. I even bought the additional templates and the dust collection port. It seems to do a decent job from my testing but not as easily as the other two machines above. I have been looking at reconditioned Festool Domino 500 set but that seems to be a one trick pony but alas excellent on what it does with floating mortises but for not alot more there's these other two machines. And then of course I'm hoping that there maybe a holiday special making it a bit easier to convince the better half how much I really need this.
Of course with the up coming shoulder replacement on Dec. 17th I may have a sympathy card to play especially if she ins't thinking about the things I do that she'll have to for at least a few months. But if I go this route I'd prefer to have it setup before the surgery to have all the heavy work out of the way.
So that's my story, anyone with some sage advice? And don't be asking about possible estate sales, I've already survived two knee replacements and a cardiac ablation procedure in the last 6 years. I'm not going anywhere soon, at least not without screaming and clawing.......
sreilly is online now
post #2 of 5 (permalink) Old 11-23-2018, 06:03 PM
the FMT Pro + Bosch 1619...
Leigh D4R + 2ea Bosch MRC23's....
post #3 of 5 (permalink) Old 11-23-2018, 07:28 PM
CharleyL's Avatar
First Name: Charley
What steered me away from the Router Boss and it's English equivalent is that, when making multiple cuts, like you would when doing dovetails, you are depending on pencil marks for positional accuracy between each pin and dovetail being cut. This holds true for any type of joint being multiple cut using this type of tool. The Router Boss is well made, but to me, it can't be as accurate as I would want due to this "positioning to pencil mark" requirement . I've watched several demonstrations of the Router Boss before coming away with this conclusion, and I ended up buying the Leigh D4R dovetail jig because the tails and pin widths and their positions are determined by the same position adjustment of the jig fingers. Set one and the other follows.
For mortise and tenon joints I watched several demonstrations of the Multi Router, I once owned a Trend M&T jig (not at all happy with it), and I had considered a Mortise Pal and other floating tenon methods.
To me, the Panto Router is very similar to a Multi Router in the way that it works. A pin follows a ready made pattern with no tolerance adjustment. There is also a Wurth machine and a similar, but cheaper version of a Multi Router being sold by Woodworkers Supply. All work about the same. In all of these you follow the edge of a pattern to cut a tenon and then set up stops to cut the matching mortise. No tolerance adjustment exists for getting a perfect tenon to mortise fit in any of these. In one demonstration that I watched the demonstrator wrapped the tenon pattern with one layer of Scotch Tape in order to increase the tenon size so the cut tenon would be a little larger to fit it's mating mortise, and the mortise size was dependent on the size accuracy of the bit used along with the way that the operator proceeded to plunge the bit into the wood. It fit, but to me it wasn't to the quality and repeatability that I was looking for.
The Leigh FMT jig can cut both the tenon and it's matching mortise with the same set up, and only the Leigh FMT provides an adjustment for fine tuning the size of the tenon to perfectly fit the matching mortise. I could find no such fine tuning adjustment in any of these other tools. I've now owned a Leigh FMT Pro jig for about 12 years, along with all of the bits and all of the patterns for Imperial sizes to use with it. It saved my back side when I took a job that required making just over 1,600 M&T joints. It paid for itself on that one job and has been in my tool arsenal ever since. I watched the Leigh demonstration at a wood show many times and asked questions of the demonstrators before buying it until I became convinced that I had to have one.
At the show they cut a tiny tenon on the end of a wooden match, and then cut a through mortise in a second wooden match that the tenon fit perfectly into. That and their display of other M&T joints that had been cut, totally convinced me that I had to have an FMT jig.
The fine tuning adjustment on the FMT is a slightly tapered pin with an adjustment knob for setting it's height. This pin rides around the outside of the pattern to cut the tenon and in a slot in the middle of the pattern to cut the matching mortise. By adjusting the pin's height, you can slightly change the size of the mortise and the matching tenon in order to achieve a perfect fit between them, and this fit is accurate and repeatable to thousandths of an inch. Once the fit is correct, you can crank out perfect fitting mortises and matching tenons of that size all day long. They can be loose for needed glue space or POP like a pop gun when dry fit and you pull them apart. Every mortise and tenon cut with those settings will be the same and to that accuracy. The settings can also be recorded so you can repeat the result using the same bit and tapered pin height and get the same results a week or month later.
I'm just a very satisfied Leigh customer. I have no connection to them otherwise.
Watch the YouTube demonstrations for each tool closely to see how they make fine adjustments for fit. Then watch the Leigh D4R and FMT demonstrations. A personal demonstration of each of these tools would be better, but once educated in what to look for, I think you will be able to see the limitations of each tool.
Charley
Central North Carolina
CharleyL is online now
post #4 of 5 (permalink) Old 11-24-2018, 08:15 AM Thread Starter
sreilly's Avatar
First Name: Steve
Charley
Thanks for the detailed reply Charley. From what I saw of the PanoRouter demo done by George at WWGOA is that the adjustments are made by moving the quill with the bearing that rides on the template either in or out. The template edge is tapered with fully in being the tightest or all the way out to the edge being the loosest. At least that's the adjustment I remember. I saw no review of doing the dovetail joints.
post #5 of 5 (permalink) Old 11-24-2018, 02:45 PM Thread Starter
sreilly's Avatar
First Name: Steve
Stick,
I finally looked at the Leigh D4R and it seems a bit $$$$ at the base price with additional $$$ if buying their accessories such as the mortise and tenon template. I'm not saying it isn't worth it but that's one model I can see when I go to my not so local Woodcraft store, hopefully 1st of the week. It doesn't appear any of these are at special pricing so there's no need to be compelled to rush. That said I don't think any dealers sell either the Router Boss or PantoRouter, yeah I've been spelling it wrong all along. Seems I'd have to go all the way out to Portland, Oregon to see one. And wrong about pricing they do offer $100 off and free shipping.
