Zero Clearance Tape - Router Forums
 21Likes
post #1 of 12 (permalink) Old 11-30-2018, 07:00 PM Thread Starter
Default Zero Clearance Tape
I had a ZC plate for my Bosch 4100 benchtop saw, but didn't want to mess up the factory plate wit a 45 degree setting so I ordered a pack of ZC tape from Fast Cap. Took longer to open the plastic package than to install.
I made a couple of cuts, and it performed well. There are 5 strips in a pack and that will be more than enough for my needs.
Herb Stoops is offline
post #2 of 12 (permalink) Old 11-30-2018, 07:40 PM
thanks Herb for the update..
Herb Stoops and mjadams61 like this.
Stick486 is offline
post #3 of 12 (permalink) Old 11-30-2018, 07:52 PM
They're supposed to help with miter saw cuts too. I may have to pick some up.
Herb Stoops likes this.
post #4 of 12 (permalink) Old 11-30-2018, 08:25 PM Thread Starter
Chuck,that is what they were originally sold for, but someone must have used them on the TS, and now they advertise them for such. I have in the past used masking tape and duct tape, but they don't hold up long and eventually will roll up and stick to the bottom of the cut and cause a problem.
post #5 of 12 (permalink) Old 12-01-2018, 02:41 AM Thread Starter
There was a question by a member of another forum ,if it changes the angle of the cut to be raised up the thickness of the tape on the cut end. Tomorrow I will cut and fit some miters and check them for square. The tape measures .53mm not sure how many inches that is.
post #6 of 12 (permalink) Old 12-01-2018, 02:57 AM
it's 1/64''...
and I'm not the mathy type...
Stick486 is offline
post #7 of 12 (permalink) Old 12-01-2018, 03:29 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I was just about to ask the same question. To get accurate angles you would have to coat the entire table with it. Not necessarily blanket the table, but enough strips to keep the project level to the blade angle.
sunnybob is offline
post #8 of 12 (permalink) Old 12-01-2018, 06:01 AM
Gene Howe's Avatar
First Name: Gene
I put it on the SCMS and haven't seen a problem with miter cut accuracy. But, I don't make picture frames, either. It does reduce tear out.
If it does cause a problem in the future, the shooting board will take care of it. But, a 1/64 would be problematic on a long bevel cut with the TS.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #9 of 12 (permalink) Old 12-01-2018, 11:49 AM
I think on a miter saw the solution was to put a piece on either side of the tables.
post #10 of 12 (permalink) Old 12-01-2018, 12:39 PM Thread Starter
Bob,
Here are some pictures of an 8" piece that a couple of inches was cut off. They seemed acceptable, and longer pieces cross shouldn't be a problem, I agree with you and Gene on the ripping a miter angle and I think Chucks suggestion would remedy that.
Danman1957 likes this.
New Woodworking Product: Never use Double-sided tape again (almost) Joe Lyddon Lobby 25 10-25-2017 08:15 PM
My New Favorite Tape Measure DonkeyHody Tools and Woodworking 36 12-07-2015 01:15 PM
Testing Peachtree double-sided tape Gaffboat Tools and Woodworking 22 11-17-2014 10:05 PM
Bench Dog Pro Plate and Zero Clearance Insert problem matt1710 Table-mounted Routing 24 07-17-2011 08:37 AM
