Purchasing my first Dado Blades - Router Forums
 22Likes
post #1 of 18 (permalink) Old 12-23-2018, 10:06 AM Thread Starter
Ed3443's Avatar
First Name: Ed
Default Purchasing my first Dado Blades
I want to buy a set of dado blades. I have a Jet supersaw--so underpowered. I would like to use the Incra Ibox which means I would need 8" instead of 6" dado's. I have thought seriously about just buying a blade for finger cuts in 8" and buying 6" dado blade. But I like the idea of using 3/4" dados. I have also heard that 8" blades spin faster and have a cleaner cut.
Then is the second quandary--which blade. I have looked at Forrest Dado King and Infinity Dadonator. I am leaning toward Infinity because of 6-chipper vs 4 and I have been really impressed with their router bits.
Any suggestions, thoughts or help would be greatly appreciated.
Danman1957 and Herb Stoops like this.
Ed3443 is offline
post #2 of 18 (permalink) Old 12-23-2018, 01:01 PM
One of the reasons they sell 6" dados is for underpowered saws. It takes more torque to run an 8" set. I ran a 6" set when I only had a 1hp direct drive Sears saw and I'm pretty sure I would have had problems with an 8" set. I also have an Ibox and I'm not aware of needing an 8" set for it? You would rarely need to extend more than 3/4" and a 6" set will do that.
You want a set that is guaranteed to leave a flat bottom and not leave "bat ears" at the corners. There are several different brands that are good such as Freud, CMT, or Amana (and others that are maybe less common). Just make sure they say flat bottomed. I know in 8" you can have a choice in 12 teeth or 24 teeth but I can't remember what the options are in 6". More teeth mean a smoother cut but more teeth require more power and cut a little slower.
Ed3443 and Herb Stoops like this.
post #3 of 18 (permalink) Old 12-23-2018, 01:03 PM
The chippers are the kicker for me. Don't own any Incra stuff that isn't great--someone there is a woodworker so their stuff makes a lot of sense and works as promised. So I'd go for the Incra 8 inch and adjust my feed rate. The Ibox jig would likely work as well with either 6 or 8 inches. Even my long-gone Delta 1hp worked fine with my 8-inch dado set, although I have a no longer available DadoWiz for that purpose that's easier to set up and use.
An increase in speed depends on increasing RPM. The difference will be the number of teeth per revolution that engage the workpiece, which may increase the smoothness of the cut edges.
Ed3443 likes this.
DesertRatTom is online now
post #4 of 18 (permalink) Old 12-23-2018, 01:29 PM
I bought a DIMAR (German made) dado set last year; I'm extremely happy with it! Cuts like a laser and clean flat bottoms.
My saw is only 1 1/2HP and i didn't notice any bogging down even with the full 3/4" wide cut.
http://www.dimar-canada.com/pdf/DadoSets8.pdf
Ed3443 likes this.
DaninVan is offline
post #5 of 18 (permalink) Old 12-23-2018, 06:24 PM
RainMan 2.0's Avatar
I bought this one from Freud . It has a dial adjustment on the one end , which I just love . If your width is out a few thousands , you just loosen your arbour nut and turn it a click.
Itís expensive, but I wouldnít use anything else
https://www.amazon.com/Freud-Dial-Wi.../dp/B000089H8P
Ed3443 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 18 (permalink) Old 12-24-2018, 01:40 AM
Yikes! That's $250 US and that doesn't include shipping to Canada in the price. That's over $300 Cdn plus taxes and shipping...
Ed3443 likes this.
DaninVan is offline
post #7 of 18 (permalink) Old 12-24-2018, 08:05 AM Thread Starter
Ed3443's Avatar
First Name: Ed
Default Ed3443
I read someplace that Ibox uses 1/2" of height itself. With a 3/4" dado (my likely max) the blade height would have to be 1 1/4" and my understanding that is the max for 6" dados. There is no wiggle room if you need 1/32 more. Am I totally confused??? I am pretty new to all of this so I think that I could have misunderstood something. If so I would much prefer to get the 6" since the saw has 1 3/4 HP running on 120V. Thank you!
Ed3443 is offline
post #8 of 18 (permalink) Old 12-24-2018, 09:36 AM
Iím pretty sure it was $340 at Windsor when I bought it . No regrets though ,as Iíve spent money more foolishly than that before
thomas1389 and Ed3443 like this.
post #9 of 18 (permalink) Old 12-24-2018, 10:14 AM
MYB
First Name: Mark
I usually only buy Freud saw blades because I have always had good luck with them but when I upgraded to a 3 hp saw I wanted an 8" dado and after reading many reviews I bought a cheap (around $100 at the time) Oshlun set that is made in China. https://www.amazon.ca/Oshlun-SDS-084...67200911&psc=1
I don't know how I could get a cleaner crisper cut by paying more than this cost. They also make a 6" set.
DesertRatTom and Ed3443 like this.
MYB is offline
post #10 of 18 (permalink) Old 12-24-2018, 01:45 PM
Yes, the wood sits on the Ibox jig so about 1/2" lost. I can't remember what the 6" set will extend above the table as I had changed to a bigger saw and 8" set by the time I bought the Ibox. My saw was rated 1hp but it drew 15 amps so regardless of what the maker claims the power between my old saw and yours is similar. One of the issues with using a heavier setup is the amount of time it takes the saw to start and get up to speed, particularly if the saw is cold. During this spin up phase the saw is drawing a lot of amps which heats the windings up and is not good for the saw. I had issues at times with the motor overload kicking out and popping the breaker once in a while.
Ed3443 likes this.
dado blade problem,ragged cut, incorrect installation of the two blades? Door County Tools and Woodworking 5 04-03-2014 08:43 PM
Dado blades Marcus Tools and Woodworking 17 12-12-2009 10:33 AM
Dado Blades jbishop Tools and Woodworking 2 12-24-2008 07:06 PM
Dado blades and other table saw specialties Mike Tools and Woodworking 3 01-05-2005 09:07 PM
