Opinion Please - Router Forums
 21Likes
post #1 of 25 (permalink) Old 01-05-2019, 08:08 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Default Opinion Please
I have two six inch Mesquite disks that I want to make into a clock. The blanks are about ready to work on but during the drying process they have gotten cracks.
The opinion I seek is how to best address the cracks. Should I drill them out and plug them, fill them with exoxy, do nothing or what do you think I should do to address the cracks.
The wood is now at about 12% moisture. My intention is to route out the back side in the shape of the clock body, drill through a 5/16" hole and mount the battery operated clock. I have some stick on roman numerals for the front side.
Currently the blanks are 2" thick and 1" thick. The two faces of each blank are parallel to each other and sanded to 60 grit in preparation to go to probably 320 grit for finishing. I plan on spraying polyurethane to help retain the bark. I will use one or maybe both to make a clock.
Let me know your opinion on what to do about the cracks.
This is a round cut from a limb. The tree was over 100 years old and was about 28" at the base. Most Mesquite trees never get this big and the person that let me cut it down after it blew over is who I am making the clock for. The rest of the tree is currently stickered and drying on my shop covered front porch. I milled the tree into about 2.5" slabs with a Wood Mizer mill. Cant wait to get to the big slabs to make turnings and jewelry boxes and so on.
Thanks in advance.
Danman1957 and Hutzul like this.
gdonham1 is offline
post #2 of 25 (permalink) Old 01-05-2019, 08:20 PM
use them as a feature..
post #3 of 25 (permalink) Old 01-05-2019, 08:36 PM
Not sure it would look any better if you filled them. And as they dry further, the cracking will probably expand a bit. I'm with Stick on this one.
jj777746 and mjadams61 like this.
DesertRatTom is online now
post #4 of 25 (permalink) Old 01-05-2019, 09:02 PM
Bob Adams's Avatar
First Name: Bob
I would fill them with epoxy and then use butterflies (Dutchmen) to keep them from cracking further.
Hutzul and mjadams61 like this.
Bob Adams is offline
post #5 of 25 (permalink) Old 01-05-2019, 10:04 PM
JOAT's Avatar
First Name: Theo
Ultimately it's your call, but I'd use as is.
JOAT is offline
post #6 of 25 (permalink) Old 01-06-2019, 01:18 AM
How long have they been cut? General rule is let them season a year per inch of thickness.
post #7 of 25 (permalink) Old 01-06-2019, 01:33 AM
I would just let them dry. If you are going to put a clock face on them, they will cover the crack. If you ar just going to put the numbers on them, then just leave them as a feature. If they grow too large for you then when they have dried out fill them with epoxy.
Cherryville Chuck and Hutzul like this.
Herb Stoops is online now
post #8 of 25 (permalink) Old 01-06-2019, 06:00 AM
dirt_dobber's Avatar
First Name: Randy
I'm also going with sticks idea... use them as permanent hour/minute hands
The clock on the left is at 8:11 and the one on the right is at 10:22
on a more serious note - be careful with that mesquite - I once got a nasty lung infection
with the sawdust. I found it also a very hard wood but beautiful when finished!
Making sawdust regularly, occasionally a project is completed.
dirt_dobber is offline
post #9 of 25 (permalink) Old 01-06-2019, 06:29 AM
Stoneface's Avatar
First Name: Frank
I agree with Herb. Leave the cracks for now as features and epoxy later if needed.
Frank
Hutzul and Herb Stoops like this.
Frank
Stoneface is offline
post #10 of 25 (permalink) Old 01-06-2019, 09:34 AM
sreilly's Avatar
First Name: Steve
Gotta go with Stick on this.
sreilly is online now
Router Lift Opinion Ken Bee Table-mounted Routing 20 07-07-2015 10:15 AM
Opinion on diy table insert Bikeworks Table-mounted Routing 6 12-19-2012 12:14 PM
Makita RP1110C router opinion giltic General Routing 10 10-25-2010 04:24 PM
Need opinion of my routed bead board top-cap. RickDel Starting Off 1 07-11-2010 08:45 PM
Need opinion and advice on this Bob N Jigs and Fixtures 6 06-13-2007 07:48 AM
