Thinking I might get a benchgrinder. 6 or 8? - Router Forums
 13Likes
post #1 of 11 (permalink) Old 01-07-2019, 05:33 AM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Default Thinking I might get a benchgrinder. 6 or 8?
I was thinking of getting a bench grinder for my shop. Im not sure Id have a ton of use for it but you know how that goes, once you get something then you seem to find uses for it you never imagined. My primary thought was sharpening my chisels. Does anyone else see this as helpful or do you just prefer to work them by hand on a diamond sharpener or stone? If I got one, is a 6 adequate or is 8 better? Im seeing all kinds ranging in price from $40 up to $200. That much difference seems ridiculous to me for just roughly shaping and sharpening a blade.
Duane Bledsoe is offline
post #2 of 11 (permalink) Old 01-07-2019, 06:35 AM
sreilly's Avatar
First Name: Steve
Hey Duane. It doesn't look like you've looked too deep. You can spend way more than $200 if you look at the T8 Tormek. I won a slow speed Rikon at my somewhat local Woodcraft and outfitted it with a couple of CBN diamond wheels for sharpening my lathe tools but can do chisels and plane blades as well. I also have the diamond stones with a few jigs for sharpening. That said the Rikon grinder is a 8" and I did need to remove the wheel housings to take full advantage of the sides of the CBN wheels.
Hope this helps some. Either way it isn't inexpensive but with good wheels you should be set for a long while.
jj777746 likes this.
sreilly is online now
post #3 of 11 (permalink) Old 01-07-2019, 08:25 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Whilst I have a Tormec and an 8" high speed grinder, the 8" half speed one shown is the one used most of the time. The chisels don't get anywhere as hot as they do on a high speed one and the Tormec is far too slow.
Harry
harrysin is offline
post #4 of 11 (permalink) Old 01-07-2019, 08:40 AM
I have an 8" but it only gets used occasionally. It is nice when the chisels need reshaping or getting deep nicks out of them and the wheels do give you the dished edge that cuts better after. Otherwise diamond hones get the job done. It takes a a fair number of sharpenings with the diamond stones to wear down the hollow grind from wheels. If the grinder comes with the coarse gray wheels you'll need to replace at least one with a white wheel. I have a hard felt wheel that I charge with green honing compound which is equivalent of 8000 grit and a follow up with it gets my chisels to where they will shave hair off my arm. I can't speak to the Tormek or Stay Sharp or any of the other systems as I haven't tried them.
Danman1957 and jj777746 like this.
post #5 of 11 (permalink) Old 01-07-2019, 09:38 AM
roxanne562001's Avatar
First Name: Roxanne
I couldn't live without a bench grinder. I use to hand sharpen all my drill bits and cold chisels. I do allot of metal work. I use it for a ton of other stuff too. I have a 6 " I think I use it almost every day. I have had it for years I think it cost about 50 bucks. I even use it to sharpen pencils. LOL
roxanne562001 is offline
post #6 of 11 (permalink) Old 01-07-2019, 09:54 AM
JOAT's Avatar
First Name: Theo
I don't use one often, but find a bench grinder a valuable addition to my shop. Had two, so gave one to my younger son. Checking around, looks like the other one followed my son out the door. So now looking for another one.
I don't use one for sharpening chisels or lathe tools tho. Find it handier, faster, and as accurate, sharpening those on a small belt sander. Got that tip from a top-of-the-line custom furniture maker years ago, it has worked out very well for me. And I only use mechanical pencils now, no sharpening at all.
JOAT is offline
post #7 of 11 (permalink) Old 01-07-2019, 11:23 AM
Danman1957's Avatar
Duane,
As Chuck stated the grinder is good for removing nicks in chisels but, that is where I stop. A bench grinder turns way to fast to use for sharpening. You need a low speed grinder for that and use the white wheel made for that purpose. I don't have a low speed grinder yet, but I will eventually buy one. For now after the grinder removes the nicks, I go to my trusted oil stone and have been teaching my students also. Like so many other aspects of woodworking, you can spend a fortune to get the latest technology, or, you can use tried and true old school that costs way less and gets the job done. How many pieces of furniture were built over centuries without water stones and diamond stones ?
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #8 of 11 (permalink) Old 01-09-2019, 09:38 AM
First Name: Art
Which ever you get be sure to replace the wheel with a good one. I use a CBN wheel and it's almost impossible to over heat my lathe chisels yet it sharpens then very quickly. A regular wheel can burn the steel almost instantly. The wheel alone was about $200.
mgmine is offline
post #9 of 11 (permalink) Old 01-09-2019, 04:15 PM
Duane (and anyone else reading this) Do not use your grinder for Aluminum, and then for steel. You can have a catastrophic failure of the grinding wheel! I'm talking about stone shrapnel here. Don't do it.
Aluminum particles basically melt into the stone's pores and fuse there; bad Karma.
DaninVan is offline
post #10 of 11 (permalink) Old 01-09-2019, 04:20 PM
DaninVan is offline
I've Been Thinking Again Ummm... Jerry Bowen Tools and Woodworking 0 05-08-2015 04:40 PM
Wishful thinking RainMan 2.0 Guide Bushings and Templates 33 08-04-2014 02:46 AM
Idle Time And Just Thinking Jerry Bowen Lobby 1 03-06-2014 02:46 PM
Time to start thinking about Christmas presents RLego General Routing 7 07-16-2012 01:51 PM
Thinking outside the box - Moving & standing up large concrete blocks, by hand!! BigJimAK Lobby 2 10-22-2009 05:06 AM
