Good track saw accessory - Router Forums
 22Likes
post #1 of 16 (permalink) Old 01-09-2019, 11:36 AM Thread Starter
Default Good track saw accessory
I see Woodpecker has a new tool for making repeatable rip cuts with a track saw. https://www.woodpeck.com/parallel-gu...7vsowtj7k7w36o As usual it isn't cheap. Between the cost of the track saw (Festool shown at around $750 plus) and the $400 accessory you are up in the price range of a pretty good contractor style table saw. This might still appeal to those who could use this setup on a jobsite or just don't have space for a TS. To me it's the concept that is interesting and there is no reason why a wooden version couldn't be built. You'd just need two strips of wood or ply and cut a series of slots in them. Then wooden stop blocks with a threaded stud would go in the appropriate slots and get locked down with a knob on the threaded stud.
The other tool I would make would be a setting gauge which would be two strips of wood joined to each other so that they slide on each other and lock at the desired length, like this bar gauge you can make with the Lee Valley clamp heads: Veritas® Bar Gauge Heads - Lee Valley Tools I might even use this with the Woodpecker jigs if I had them. They would ensure that both ends were set equally so that you would stay parallel to the edge of the sheet. It's often the thinking behind the problem solving that I find interesting, in this case more so that Woodpeck's expensive solution. I do give them credit for a job well done.
TenGees, Nickp and peterbata like this.
post #2 of 16 (permalink) Old 01-09-2019, 12:41 PM
I think something like this would be very easy to cobble together in wood. You only need to butt the rail against a secured stop to do this. Stop block on a stick. At $400 I think I'll pass.
post #3 of 16 (permalink) Old 01-10-2019, 06:57 AM
I have a similar arrangement made by Rip Dogs (unfortunately no longer available) which works very well, although it becomes a little cumbersome trying to move the rail with the arms attached in a smallish work space.
The following video shows a very ingenious home-made version, made with scraps and offcuts, that does the same basic job - although you wold have to make one for each width, but could have a collection for the various "standard" widths that you rip - e.g. upper and lower cabinet sides, shelves, etc. (although the shelves could be made using a shim between the fence and edge of the material). Building the jig starts at around 4:00
There is also a video by Dan Pattison of a variable version as mentioned by @Cherryville Chuck, including the adjustable setting fixture.
tomp913 is offline
post #4 of 16 (permalink) Old 01-10-2019, 08:38 AM
sreilly's Avatar
First Name: Steve
Nice tip Chuck and the video Tom posted really shows how east this could be for scrap wood guides. Wish I had seen this before making all the shop base cabinets but the table saw served me well after breaking down the sheet stock to more manageable sizes.
sreilly is offline
post #5 of 16 (permalink) Old 01-10-2019, 11:10 AM
What you need is two pieces of 4 ft long, straight, 1x1.5 inch stock, a couple of short pieces of thin stock to use as stop blocks and a couple of small clamps to hold the stop blocks.
Measure and mark the width you want to cut and set up the track to cut that line. Lay the first stick so it touches the track and clamp the stop block on, under the stick so it is snug against the edge of the sheet. Flip the clamped stick over and lay the second stick on top so it touches the stop block. Clamp the second stop block on so it touches the open end of the first stick (see illustration below-stop blocks are red). Now you have two exact length sticks you can use to make both ends of the track perfectly parallel to the cutoff edge.
This will give you repeatable cuts on full sheets of flat stock. If you're breaking down the sheet into several different size pieces, you repeat this measure, set stop block(s), line up and cut process for each new piece. The advantage of this is the no matter what size you cut, the cut-line will be parallel to the cutoff edge. And you get repeatability if you're making the same cuts on several sheets of ply, for example, making a set of same size cabinets.
I was thinking you could adhere a tape rule to the sticks, but I don't think that would be very helpful compared to careful setting of stop blocks. The important measurement is the width of the cutoff marked at least top and bottom to set the track. Setting the first stop block assures that the second will be identical, thus the cut will be perfectly parallel to the edge.
If you want, you can send me $400 and I'll send you some sticks, clamps and stop blocks. Heck, I'll even paint them red and silver for ya.
Name:	track saw parallel sticks.jpg
Cherryville Chuck and TenGees like this.
post #6 of 16 (permalink) Old 01-10-2019, 02:25 PM
Just a little more thought on this. You could mark your Desert Rat bars for different width cuts, something like a story stick. But you'd want to make a stop block that indexed to the stick and sheet so it would line up as square as possible, something like the illustration. Line the sticks up so they are 90 to the sheet's edge, clamp the stop block on flush to the edge, then add the small positioning bar, pre drilled or glued. Let it dry then add two screws to make it strong. From then on the once you apply the block, the bars will be 90 to the sheet goods' edge.
You could put on a sticky measuring tape that accounts for the width of the track, but I think fine pencil marks would work out better in the end. You want the cut off piece to be an exact width, which may vary, but you'll always want the cutoff edges to be parallel.
OK, for your $400 bucks I'll add the little alignment tab and supply a longer stop block for better precision alignment. Take that Woodpeckers!
Name:	track saw parallel sticks STOP block.jpg
post #7 of 16 (permalink) Old 01-10-2019, 06:01 PM
Gosh, no takers yet on my pecker wood track saw perfect cut super jig? It's silver and red you know. If you want the pure, natural wood, you-finish model, it's 15 percent off!
Wildwood likes this.
post #8 of 16 (permalink) Old 01-10-2019, 06:20 PM
mimac's Avatar
First Name: Brian
Only if it is the peter pecker pickled pepper model able to withstand a powerful paralyzing pacadermic punch.
mimac is offline
post #9 of 16 (permalink) Old 01-10-2019, 07:19 PM
Oh, well, I'll provide a free replacement in case that happens, or it catches on fire, or wood worms attack the parts. I'll provide a lifetime, free replacement guarantee (for my lifetime of course).
Read the small print for details
Name:	lifetime guarantee.jpg
mimac and TenGees like this.
post #10 of 16 (permalink) Old 01-10-2019, 08:32 PM
Nickp's Avatar
First Name: Nick
Great product...in the traditional Woodpecker style...
I use an edge guide, stair gauges and a carpenter square to line up the cut. Very repeatable. Similar to Chuck's reference to the Veritas pieces.
DesertRatTom likes this.
Nick
Nickp is offline
BOSCH 1617EVS mounting on a router table ironman21 Table-mounted Routing 59 10-31-2018 05:15 PM
First box joints Debbie Show N' Tell 39 04-10-2018 06:35 PM
New comer to forum ironman21 New Member Introductions 24 03-09-2018 12:27 AM
normie normie New Member Introductions 11 01-17-2018 11:42 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
