Correct Bandsaw Blade size after installing riser block - Page 3 - Router Forums
 16Likes
post #21 of 25 (permalink) Old 01-16-2019, 11:38 PM
If you have an old blade, just measure it for the replacement.
Herb Stoops is offline
post #22 of 25 (permalink) Old 01-17-2019, 07:45 AM
Default 14" Grizzly
105" is the correct size. I have a 14" saw with the riser and the 105" came with the kit. I've a selection of 105's and they work fine. Mine is a Grizzly, also.
Eric's Splinter is offline
post #23 of 25 (permalink) Old 01-21-2019, 11:17 AM
First Name: john
You read it wrong. 14" bandsaws use 93" blades. Then add 12" for the riser block
DesertRatTom likes this.
johnjory is offline
post #24 of 25 (permalink) Old 01-22-2019, 11:54 AM
MikeMa's Avatar
Please don't assume that all 14" bandsaws have the same blade. The newer ones do use a 93" blade, some of the older ones use a longer one. If you check the specs for the OPs bandsaw, it does indicate a 98" blade, so a 110" blade with a 6" riser block would be needed.
Spec for OP's Bandsaw: https://www.grizzly.com/products/Gri...Bandsaw/G1019Z
To add to that, I had a friend who had a 14" Jet bandsaw, looking at it, it appeared to be the same castings as my Grizzly G0555P. As he didn't use that saw often, he gave me a couple blades to use on my bandsaw. When I got them home, they wouldn't fit. Turns out his saw needed a 92" blade. Most of the 14" band saws on the market now use a 93", but that hasn't always been true.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #25 of 25 (permalink) Old 01-22-2019, 02:13 PM
That's true. I have an 18" saw and my blades are 129 I think and I'm thinking of trying a little shorter as the slide that holds the upper axle and wheel is a sticking above the adjustment yoke a little more than I care for. Standard for 18 is around 132 to 133 I think. I see in this attached chart that Grizzly sell one 18" that takes a 146" blade. It must have a tall throat. This chart may be helpful: https://www.pswood.com/blade-lenghts/
MikeMa likes this.
small hobby bandsaw blade tension? kibodwin Tools and Woodworking 9 02-20-2015 11:06 AM
Bandsaw tire size Scorpiodad78 Tools and Woodworking 4 05-20-2013 01:37 PM
correct way to sharpen a bandsaw blade GRLevel3 Tools and Woodworking 15 09-27-2012 09:45 AM
Bandsaw blade for oak? Chris Curl Tools and Woodworking 4 04-15-2012 12:47 AM
Correct size bit? rastus Guide Bushings and Templates 6 12-27-2010 07:20 PM
