Correct Bandsaw Blade size after installing riser block - Router Forums
 16Likes
post #1 of 25 (permalink) Old 01-09-2019, 11:20 PM Thread Starter
Default Correct Bandsaw Blade size after installing riser block
I have an old Grizzly 1019z 14 1/2 bandsaw, which used 98” blades.
I recent installed a 6” riser block - and purchased 111” blades - which I though was correct based off my math.
They are too big - so before ordering more I am trying to figure out the correct size. Should be be 110” or should I go even shorter then that?
Thanks in advance.
Sent from my iPhone using Tapatalk
pofo14 is offline
post #2 of 25 (permalink) Old 01-10-2019, 12:09 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
6" rise = 12" extra length.
98 + 12 +110
111 is 1" too long.
sunnybob is offline
post #3 of 25 (permalink) Old 01-10-2019, 06:47 AM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute complete your profile with first name to clear the N/a in the side panel and so we'll know what to call you.
What sort of projects are you doing? Resawing is involved, I assume... We like photos!
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 25 (permalink) Old 01-10-2019, 07:39 PM
Mine takes a 105" blade, a 108 is too long.
https://www.amazon.com/Jet-708717-JR.../dp/B0000223N9
This kit is the same as the Grizly,Delta,Ridgid,Jet 14" riser.
Herb Stoops is online now
post #5 of 25 (permalink) Old 01-10-2019, 08:01 PM
Nickp's Avatar
First Name: Nick
Might be time to take out the ole tape measure and literally put it around the wheels...
I did a quick search and found an article that indicates 105 3/4"...although it refers to it a bit left-handed (no offense to lefties)
WoodCentral's BP Archives: Grizzly 1019 Bandsaw
Nick
Nickp is online now
post #6 of 25 (permalink) Old 01-10-2019, 08:24 PM Thread Starter
98 + 12 +110
111 is 1" too long.
Thanks. I think this is the right size.
pofo14 is offline
post #7 of 25 (permalink) Old 01-10-2019, 08:29 PM
hawkeye10's Avatar
First Name: Don
My Grizzly 14" saw takes blades that are 105" long as well. I buy Timber Wolf blades and if you need help with blades they are more than happy to answer any question you might have.
https://timberwolfblades.com/
Herb Stoops likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 25 (permalink) Old 01-10-2019, 09:35 PM
You could get them shortened. You'll have to check around your area to see who can do it. Lee Valley sells a splicing kit. Some of the outfits that sell blades might have that too.
post #9 of 25 (permalink) Old 01-10-2019, 11:00 PM
We have a saw sharpening shop that will do it for $12.00.
@pofo 14
110" is way too long, look at that link I posted the correct length is listed, if you scroll down to the specifications for that riser block kit.
Get the most from your band saw by increasing its cutting height capacity from 6" all the way up to 12"! Upgrade for 14" band saws. Increases blade requirements from 93-1/2" to 105". Comes complete with everything needed to convert your saw quickly and easily. Kit includes: Riser block, blade guard assembly, guide post, mounting hardware and instructions. Must be used with 105" band saw blade.
TenGees likes this.
post #10 of 25 (permalink) Old 01-11-2019, 07:29 AM
TenGees's Avatar
First Name: Paul
I have a Porter Cable 14" and I believe it's the same saw sold under many names... It's a 93-1/2" blade like Herb's. Are you sure your saw took a 98"?
TenGees is offline
small hobby bandsaw blade tension? kibodwin Tools and Woodworking 9 02-20-2015 11:06 AM
Bandsaw tire size Scorpiodad78 Tools and Woodworking 4 05-20-2013 01:37 PM
correct way to sharpen a bandsaw blade GRLevel3 Tools and Woodworking 15 09-27-2012 09:45 AM
Bandsaw blade for oak? Chris Curl Tools and Woodworking 4 04-15-2012 12:47 AM
Correct size bit? rastus Guide Bushings and Templates 6 12-27-2010 07:20 PM
